Old 4th December 2006, 11:43 PM   #11
clem_o is offline clem_o  Philippines
Originally posted by AndrewT
and the other half can't open it.
Thanks for putting up the pic, powerbecker...
Hi Andrew,
What seems to be the problem? I''ve managed to open the file as well, though haven't had the time to play with it...
Cheers!
Old 4th December 2006, 11:48 PM   #12
Bonsai is online now Bonsai  Taiwan
my error - they should both be set to very low values or removed - I was playing around with the values before I posted. Note I did my sims with R1 and R2 = 10 Ohms.
bonsai
http://www.hifisonix.com/
Old 5th December 2006, 04:59 AM   #13
Some minor corrections and I've used more conventional resistor values. Distortion now down to 0.02 at 20KHz into 8 Ohms and 0.1 into 2 Ohms.
This is quite a good result and I'd expect after placing 20-30dB global feedback around this stage (i.e. as in a complete amplifier system), distortion would be very low.
bonsai
Old 5th December 2006, 06:08 AM   #14
lineup is offline lineup  Sweden
lineup's Avatar
this will be very interesting, to see your results
good linearity in each stage, also in the output stage
via local resistor degeneration feedbacks
or using other local feedback techniques
this is the way to good linearity and low overall power amplifier distortion
- and possibly fast amplifiers keeping linearity
we have read many times in forum:
global feedback is good .... used in the right way
but not when used as a substitute for bad design and great in-linearity in the local stages
good properly designed local stages
reduces the call for high amounts of global feedback
= high closed loop feedback factor
This has been expressed, one way or another,
by just about any good knowledge amplifier person
in this forum
Including the Very Master of practical use of This design method: NELSON PASS
and another sensible clever OldTimer: HUGH 'AKSA' DEAN
good luck boys!
you are on the very right track here
and in very very good company
lineup
Lineup Audio Amplifier Laboratory
http://lineup.awardspace.com/
lineup
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
TDA1541 bipolar zero error ? Bernhard Digital Source 0 15th March 2005 09:06 PM
Another error correction output stage. Mr Evil Solid State 63 14th February 2005 11:26 AM
A way to get rid of bipolar zero error AD1865 Digital Source 24 22nd October 2004 12:30 AM
Page generated in 0.11082 seconds (58.27% PHP - 41.73% MySQL) with 11 queries
