opa627ap/bp
opa627ap/bp
Old 30th December 2002, 06:57 AM   #11
ppl is offline ppl  United States
ppl's Avatar
I have used both the OPA-627AP and OPA-627BP grades in a Headphone Amp with a closed loop gain of 20 dB and the AP grades produced DC offset voltages on the Output from less than 1 Mv to over 10 MV by going to the BP grade this DC voltage on the output went down to Less than 1 Mv and typicaly 0.002 MV consistent on 12 different devices. so if this is of importence to you and your Circuit is Direct coupled then to save having to hand select the Op Amp i would use the BP grade.
Old 30th December 2002, 07:33 AM   #12
macka is offline macka
macka's Avatar
For those who are interested I have a great article on class A biasing of audio chips from Audio Electronic some years ago.
The article refers to the merits of various chips according to application, however the glory goes to the Borbley Fet line stages for sound qulaity over all other options.... understandably so.
The advantages of chip biasing into class A are there for mainly pro audio where you are really pumping towards 20+ dba input 600 ohms, such as a mixing desk.
Into relatively high impediances the noise/disrtion cancelled mechanisms in these advanced chips is very good.
However the gross feedback appliedk for unity gain of these devices is what kills the music compared to a nice simple discrete fte buffer aka Pass.
regards
ian
Old 30th December 2002, 09:27 AM   #13
Wombat is offline Wombat  Germany
Wombat's Avatar
Hello macka!
How can we get to this article?
Thanks in advance.
If time permits - stuff some parsley in your ears and listen how it grows!
Old 30th December 2002, 10:21 AM   #14
ALW is offline ALW  United Kingdom
Default Wow!
...produced DC offset voltages on the Output from less than 1 Mv to over 10 MV by going to the BP grade...
Wow - I thought most op-amps were limited to much lower supply V's than this, must have a multiplier stage built-in
Tee hee!
Andy.
P.S. I've also found that with good modern op-amps (e.g. AD86x0) the class A thing seems to degrade rather than improve. It works better with a current source than a resistor, but doesn't make things sound better in the way I want them to.
Old 30th December 2002, 10:47 AM   #15
macka's Avatar
Oh,
Its will be a fair size pfd, so zip me your email address, I think my email message is enabled.
I'll scan if off you in the next couple of days,
regards
Ian
Old 30th December 2002, 12:21 PM   #16
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
It is standard to write mV for milliVolt instead of MV which means MegaVolt. Same for mA for milliAmpere etc.
Concerning the subject: I never remarked any sonical difference between AP and BP versions of the OPA627. Only offset voltages differ IMO. Nevertheless I prefer to use BP's just in case.
It's only audio. Member of the non modular PCB design committee
Old 30th December 2002, 12:22 PM   #17
Bobken is offline Bobken  United Kingdom
Originally posted by CraigBuckingham
Bobken,
No need to be so sensitive.
Costiss (who started the thread) was asking for opinions and I was one of many offering one.
It was that simple, nothing more nothing less.
Regards, Craig.
Hi Craig,
I was not being "sensitive", but, with respect, the matter is defintely *not* "that simple" as you suggest. Had it been, I wouldn't have made any further comment, nor would I have wasted further time in writing this.
Having attempted to help Costiss by relating some relevant *factual* experiences of my own, your views virtually directly contradicted what I said, without apparently you even having tried this out for yourself.
If you had made any such comparisons, why didn't you say so, together with the location you had tried them in - which would be relevant, rather than merely expressing an opinion?
How helpful (as opposed to being misleading) to Costiss in reaching a conclusion as to what to do in his case, is that?
Also, you then went on to categorically state (with apparent authority, which might similarly have mislead Costiss) that operating these devices in class 'A' was the way to go, possibly because you had read about it somewhere else!
The reason I am guessing this is, if like me you had already tried that mod with the 'A' grade OPAs for yourself, you would have discovered (like me, and Peranders & Wombat, it appears!) that this particular mod is certainly not universally beneficial, if it is any improvement at all!
I have no wish to cross swords with you, and my only motive is to *help* Costiss, which gave rise to my original caveat over costs etc.
It was also for a similar reason that I didn't comment on the AD825 he asked about, which I have also used (and like), but as I have not directly A/B'd it with an OPA, any guesses on my part would not have been of any real value to him.
Bob
Old 30th December 2002, 12:46 PM   #18
protos is offline protos  Greece
protos's Avatar
I recently changed the 4 opa 134PA in my perp. tech. Dac for opa 627 AP with beneficial effects. I see there is also a opa 637 that seems the same but has a much higher slew rate (135V/us vs 55V/us). Has anybody tried these?
Old 30th December 2002, 12:55 PM   #19
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
opa627ap/bp
627 and 637 is the same chip except for a compensation cap and you can't use the 637 in low gain applications, not stable. If you can(gain >10), use 637, higher gain and higher amount of feedback is possible. Better is not always "better".
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 74 pcb's ordered, 74 paid. Still possible to sign up.
Old 30th December 2002, 01:01 PM   #20
ppl's Avatar
Ok Now that we have the Mv and mV thing over. My thoughts on Current sourcing an Opamps output stage to obtain class A Bias. A resistor as the Current source or current sink for those Critics. i tride in the late 1970's and while it smoothed the sound out in the opamps i tried them with LM-353,LM-356,NE-5532, and a host of others. The resistor in addition striped all the Dynamics out and in some devices created DC offset voltages that were Higher than Without the resistor this was apperently because of using too much Current so i backed down the Current from 10 mA to 4. this improved the DC offset. The Circuits this method was used on rainged from Line Level gain stages to RIAA phono preamps to I/V converters. Since the resistor was giving what i considered less than perfect results i went to an Active current source Via the CRD diodes these are a J-fet and resistor inside a Glass diode case. and range in Current from about 0.33 mA to about 5 mA. These devices improved over the resistor method alot.These Current reg Diodes can get spendy so i next used a jfet and an external resistor that cost less and did the same thing. the only apperent advantage in the CRD was the High Voltage Complience of about 100 Volts vs the 20-30 Volts of most J-Fets. With Opamps this is not a issue.
These were my findings in the Late 1970's to the Mid 1980's after that Opamps were introduced that were IMHO accurate enough to reveal the Limitations of just a Current source while these newer Op Amps still smoothed out with a CRD, the CRD seemed to strip away the Detail. Investigation and conversations with others showed that placing a small resistor between the Current source and its load in this case an Op Amps output. would Buffer the Non linear capacitence of the Current source and this did improve the sound. I later used a jfet cascode current source and an isolating resistor. this is the only circuit i have used so far that smoothes out the Sound while not also degrading other as pects of the Performance. so far this method has improved all Opamp circuits i have used it on and with all Opamps including the New AD-8610. I should add that most of the Opamp circuits i use the method on are buffered using an Active open loop Buffer IC Like the BB BUF-634 and other's.
opa627ap/bpHide this!Advertise here!
Looking to buy BB OPA627AP/BP Opamps dtm1962 Swap Meet 2 10th January 2009 07:59 PM
(19) BB/TI OPA627AP/BP $200.00 shipped KevinLee Swap Meet 0 30th November 2006 07:32 PM
BB OPA627AP/BP for sale KevinLee Swap Meet 1 19th November 2006 10:40 PM
F/s Burrbrown Opa627ap sma Swap Meet 0 12th October 2004 11:42 AM
Copyright ©1999-2017 diyAudio
