Old 3rd December 2006, 09:17 PM   #1
nlinus is offline nlinus  Sweden
nlinus's Avatar
Default Nad c340 input selector
I'm having problems with the input selector. I seems like all the inputs are active at the same time, so the signals get mixed and distorted.
Does anyone know if it's a common problem in these models? What should I check out first?
Does anyone have a schematic for this amplifier?
Old 3rd December 2006, 09:35 PM   #2
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Have you tried to connect only one input source? I've once solved a similar problem with someone who connected an analogue rec/play in/output the wrong way around....
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 13th January 2007, 11:24 AM   #3
nlinus's Avatar
No, I haven't tried that.
I Have heard of at least to more owners of these amplifiers with the same problem. They got it fixed, but had to pay 1400 SEK (about 200 USD) for it. Not really worth it...
Old 13th January 2007, 03:05 PM   #4
v-bro's Avatar
Well, with all pre/integrated amps every source goes to the rec-outputs. Just the same the rec-outputs go to every source?
Old 16th January 2007, 06:06 PM   #5
nlinus's Avatar
Can someone who knows point out on this pic where the actual input switching is? I was looking for some relays or something but can't se them..
Old 16th January 2007, 06:06 PM   #6
nlinus's Avatar
At a closer look i seems like it's the Toshiba TC9273N that makes the shifting between inputs.
Is it possible that this component may have broke in such way that all the inputs are activates at the same time?
Old 16th January 2007, 11:42 PM   #7
v-bro's Avatar
Maybe you can measure it with an ohms meter?
Old 17th January 2007, 12:18 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi nlinus,
Yup.
Yup. Also check all your ground traces to make sure it didn't blow open, possibly destroying the chip at the same time.
Hi vbro,
Nope. Don't do it.
-Chris
Old 17th January 2007, 12:02 PM   #9
nlinus's Avatar
Does anyone know where I can buy the TC9273N-010?
I have googled for about two hours, but can't find anything but dealers that sells quantities like 1000items and more.
Is there a big difference between the models? I have found -007, -008, -009, -009... ...
Old 17th January 2007, 12:19 PM   #10
a solid state input selector!
Is it worth saving/resurrecting?
What about inserting a real switch selector and hard wiring the switch output into the PCB after that Tosh chip? (That is deliberately derogatory!)
Or
making up a relay switching selector PCB?
There's sufficient room in there for many projects!
Input selector Simo88 Everything Else 25 15th July 2009 01:33 AM
Boz AP1.7 Input Selector PCB Stones Pass Labs 2 14th November 2006 06:08 AM
input selector lawbadman Digital Source 8 10th September 2005 09:45 AM
Input Selector Semir Solid State 7 28th December 2004 06:18 AM
Input selector: need help Cobra2 Parts 1 8th March 2003 07:31 AM
Copyright ©1999-2013 diyAudio
