Old 3rd December 2006, 08:02 PM   #1
bogdan_borko's Avatar
Default Oen loop preamp topology questions
I`m still a biginer in a audio construction water and there`s some things I`d like to ask...
1. I noticed that the distortion (let`s cosider only preamplifiers) could be pulled to the wanishing levels using local feedbac only! (High degeneration)
I made the open loop single ended (two stage) mosfet preamplifier and the simulation results are VERY good:
harmonic content below fundamental at 3V output:
2nd-80dB
3rd-113dB
5th-124dB
distortion at 100KHz=0.03%
(Open loop) bandwidth 300KHz(-1dB)
THE MAIN QUESTION:
If we do not cosider that preamp is capacitor coupled and it runs on 240V(so it is more expensive), WHY designer use a global feedback over local? Is that only the money issue or this topology has other disadvantages? (the thread is related only to the preamps)
CHEERS!
preamp topology gearheadgene Solid State 22 23rd June 2011 10:17 PM
Ayre V3 proto topology for preamp? maxpou Solid State 4 20th March 2008 08:06 PM
topology for preamp, single ended or complimentary maxpou Solid State 7 10th January 2008 11:41 AM
Preamp topology regarding placement of Pot dine1967 Chip Amps 1 13th April 2006 08:23 PM
Aleph's Topology Questions SeanPool Pass Labs 4 7th February 2004 04:16 PM
Page generated in 0.07020 seconds (67.49% PHP - 32.51% MySQL) with 10 queries
