#11 |
http://www.stereophile.com/reference/60/
Very close to real life, other than they it does not produce sound, and costs much less to repair if any prototype amp dumps too much current on it. One would need a large heatsink and 50-100W resistors at the right places. Patrick |
#12 |
which is the whole point of using big simple resistors in the first place.
Of course it deosn't emulate a real speaker load, but when I first hook up my new whizzy-bang 100W amp and wish to check stability, temp rise, drift etc I an NOT going to hook it up to $1K worth of speakers! That comes later when I know it is going to be a gentleman |
#13 |
I wonder how one can really check stability without a reactive load. Of course one does not want to hook up to $1k speakers.
The circuit by John Atkinson costs about $50, so not much worst than resistors, but a lot closer to real speaker loads, IMHO. Patrick |
#14 | |
Use a crude R to check power, temperature, drift etc. THEN, when you are sure the amp is basically kosher, start adding parallel C's, series L's etc and finally a real speaker. |
#15 |
Hi
As a dummy test load I use two old 12" 8ohm speakers. I have only damaged the cone once and I just glued it back together again and the speakers are back in service as a test load. I do not think you can beat this as a first test load as it even produces nice sounds if everything goes well. I am currently using old goodmans speakers and I have a pair of B&W ready if needed in the future. The only problems this sometimes causes is form my wife who thinks I should throw away some of this old gear! Don |
#16 |
VBE voltages and all stuff.
It is enougth and reasonable...low cost and very easy to install. But if you intend to make detailed measurements you will need a more realistic load. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#17 |
Audio Junkie
I have a very very large heatsink with 8x Dale 250watt 4 ohm resistors mounted on it! I have it wired up so i can run stereo at 4 or 8 ohms.
I only use it for basic test's. after i have rebuilt a power amp or something i will run the amp up to clip and let is sit there for a good 15 minutes just to cook the amp in a bit and make sure there is no infant failure. (BTW, even with a 500wpc@8 ohm amp running at clip, i have only barly got the heatsink warm to the touch!) After that then i will let the amp cool and i have beat up old pair of Fischer speakers i use and run some music through the amp for several hours at various levels. Once i am satisified the amp will live without any funkyness killing the speakers, i will usually take it to my practice room and hook it up to an old pair of DLK speakers and crank it up for some Bass Practice. if it makes it through a few sessions of that. then i will consider moving it into the listening room and hooking it up to my main speakers. Zc |
#18 |
I use 20 Ohm resistors crucified inside of a box from computer power supply with 12V fan, I soldered'em for 4 Ohm total.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#19 | |
Also for developing an amplifier design there are a lot of things that need to be "taken care of" before you get to worrying about the peculiarities of speakers. In fact, a load that looks like a speaker could, in theory, lead one to develop a design that was optimum for one speaker but a mess with anything that deviates far from that. The principle benefit of speaker-like load is probably to facilitate the development of an amplifier that is as indifferent as possible to different speaker characteristics. |
#20 |
Are loads that will be perceived as something perfect to the amplifier...the amplifier will "see" a nice load...not a real complex load that we have using strange cables, crazy crossovers and reactive speakers.
If you like to check those crazy things, produce a reflectometer...the same used to Radio Frequency, and check the return patch...adjust zero the going signal to full pointer deflection and observe what will return.....the return is a visual information about the mismatch you have. Use full power and high frequencies inside the audible range. Those copper bars need to be in close contact, and insulated, they will capture the magnetic field that will be formed around those copper bars....this will be rectified and a capacitor to audio frequencies will help to filter (223).... the switch will select the going and returning signals (they appear simultaneously, but to allow you to use only one microamperimeter, we have installed the switch) Those mismatch happens related phase.... and you can understand as some "returning and lost energy) Install a resistor and you will see that this return is minimum.... this will means that the resistance is an excelent load....but do not produce sound, and it is a fake load to the amplifier that will behave very different when connected to real loads....the amplifier can even oscilate with a speaker and not oscilate with a resistance.. When testing using a real speaker...you will see the crazy mismatch, and this will be different depending from the frequency..of course. Real life sound reproduction have to face the "damn piston"...the speaker....moving both directions...having inductance, resistance and capacitance... the weekest part of the entire audio chain.... the final result will depend of the speaker, as it will distort more than the amplifier and the audio source. Good matched amplifiers sounds better than the ones not so good matched....of course Tophologie plays a lot about that We have a lot of guys reducing amplifier distortion to minimum...when the speaker will create much more than that....unfortunattelly this is something alike to have poluted water to drink...and to reduce it's polution, people are washing the glasses many times...to reduce polution. regards, Carlos
| mod cheap marantz player into great top load transport (cdm1 mkII) Long. | bryanj | Digital Source | 4 | 28th January 2010 07:33 AM |
| A simple active DC dummy load for PSU testing | Bootstrapper | Power Supplies | 42 | 17th August 2008 08:57 PM |
| Simple/cheap DAC? | Znyper | Digital Source | 9 | 15th January 2008 08:52 AM |
| Good & simple chip amp for 2-ohm load? | Otherwise | Chip Amps | 7 | 8th July 2003 07:21 PM |
| simple, cheap, 6L6 amp? help | trespasser_guy | Tubes / Valves | 54 | 22nd March 2003 02:03 AM |
| Page generated in 0.13801 seconds (75.71% PHP - 24.29% MySQL) with 11 queries |
