Roll off power amp low end? Roll off power amp low end? - diyAudio
Old 2nd December 2006, 05:22 PM   #1
audiobomber is offline audiobomber  Canada
audiobomber's Avatar
Default Roll off power amp low end?
To mate my main speakers and subs with a perfect L-R 4th order filter, I need to filter my amp output, -3 dB @ 70 Hz, 12 dB per octave. Amp input impedance is specified as 22kOhms.
What's the best way to roll off the bottom end of my power amp? A couple of caps in series on each input to the amp? A friend suggested a cap in series with the signal and an inductor bypass, as in a loudspeaker, but I don't know if you could even get an inductor with that low a value.
Right now I'm using a pair of FMod filters that do the job and are very convenient. Unfortunately they add the merest touch of roughness in the midrange, and I think I can do better with premium parts inside the amp.
Dan
Old 3rd December 2006, 06:09 PM   #2
Anyone?
Dan
Old 3rd December 2006, 06:29 PM   #3
ocool_15 is offline ocool_15  Canada
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
try searching google or the forums for active filter and op amp. WinISD even includes a calculator.
Old 3rd December 2006, 07:17 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
Default Active filter crossover xover 2nd order Linkwitz-Riley 12dB
What's the best way to roll off the bottom end of my power amp? .
A Linkwitz-Riley 12dB (2nd order) active filter using Op-Amp
as already told.
This is placed BEFORE the amplifier 22kohm input.
So the load for this filter Op-Amp will be 22kohm
which is no problem for example for one OPA2134
which I recommend.
It is perfect to use for active filters applications.
To learn about such filters
you can find formulas and circuits
at LINKWITZ HimSelf website!
(yes, it is the very alive person that has given name to Linkwitz-Riley filters!)
http://www.linkwitzlab.com/
Another great resource with good info about crossovers and filters
using op-amps is
ESP Rod Elliott projects and articles and tutorials website.
You will find articles about active filters and loudspeakers filters projects,
if you search a bit!
http://sound.westhost.com/site-map.htm
lineup active and posting diyaudio member
lineup
Roll off power amp low end?Hide this!Advertise here!
Highs roll off wicked1 Tubes / Valves 3 5th April 2008 10:42 PM
Roll off frequency. Katapum Tubes / Valves 8 24th April 2007 09:49 PM
best amp for rock n roll sub_arctor Tubes / Valves 19 19th October 2006 11:44 PM
Closed box roll off, a question SSassen Subwoofers 5 17th March 2005 03:02 AM
Copyright ©1999-2017 diyAudio
