Looking for a schematic. Can anyone help me?
I was told it is working, but volume control is (ribbon cable, plus one more) disconnected and RCA input is connected directly to the amp. input socket on the main board , so it is running at full power. My guess that all is missing - two plastic buttons/extenders on front panel for Volume Control and one for Right Balance. The actual tiny pushbuttons/switches on the board (I can see them) are OK. No remote control supplied... |
#2 |
Steve
Sounds like a real top-notch tech wannabe got to the unit before you. Did this unit come from Georgetowne Ontario...Just joking....I'd be scoping out ebay for a parts donor. I have no idea if OEM parts are still available??Is it a motorized volume control? If you need one check this out.http://www.altronics.com.au/index.as...=item&id=K5026 Well keep your stick on the ice we are all in this together.LOL Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
Dave,
The volume control is pushbuttons (up/down), no motor. Parts, I beleive, are still available from Pioneer service center, but very expensive (Google for SA-1270). The amp uses one pair 2SA1302/2SC3281 per channel, all transistors, 2 Mitsubishi chips (maybe opamps) and input selector TC9164N (Toshiba). On the negative side, it has only 2 electrolytics in the power supply - Elna 8,200 mkf, 71 V. |
#4 |
Steve
So have you tried putting it back to original configuration to at least check if the volume control still functions? Dave
#5 |
Yes, I reconnected the ribbons to the main board. The VC is functional, because I see bargraph power meter is progessing. Apparently, PM is controlled by pushbuttons - not by actual input signal, because embedded Spectrum Analyzer is barely moving. No signal out to speaker. All LEDs are functional.
I suspect, I need to probe signal around input selector IC. Someone on Internet was asking about this chip too. But, it is just a toy for me, not a priority. |
| Pioneer A-676 amplifier schematic needed | pinco | Solid State | 3 | 17th April 2010 12:14 AM |
| Pioneer AX10Ai AV Amplifier DAC Queries | markabuckley | Digital Source | 0 | 13th May 2009 04:44 PM |
| Pioneer SA-710 Amplifier | Scott_drake | Solid State | 6 | 28th March 2009 02:47 PM |
| pioneer sa 608 amplifier | peter hawthorne | Solid State | 2 | 4th October 2007 02:30 PM |
| Page generated in 0.11490 seconds (52.24% PHP - 47.76% MySQL) with 10 queries |
