Power Supply - need to reduce voltage - any hint?
Old 1st December 2006, 03:09 PM   #1
deiksac is offline deiksac  Czech Republic
Send a message via ICQ to deiksac
Default Power Supply - need to reduce voltage - any hint?
I have one Alesis Matica 500 with one dead channel at home. I decided to replace the dead channel with a chipamp (for biamping a small PA) but Maticas supply rails are running quite high - +-63V. Once I saw a PS design using discrete transistors to reduce voltage - could anyone point me to something like that? I wasn't able to find such a thing using either google or local search :-(
Old 1st December 2006, 03:20 PM   #2
Spev is offline Spev  United Kingdom
what output voltage are you after?
LM317/LM337 may just do the job
Old 1st December 2006, 05:55 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
LM317 is a bit weak. LM338 is better.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 1st December 2006, 06:19 PM   #4
R.I.P.
a chipamp with a regulator from +-63Vdc. That is one heck of a regulator dissipation!
Buy a discrete amp that works off +-63Vdc.
regards Andrew T.
Old 1st December 2006, 06:24 PM   #5
paulb is offline paulb  Canada
Or just use the + side of the supply, and use a chipamp configured for a single-ended power supply. If you're biamping, use this for the tweeter as you probably want a capacitor in series with the tweeter anyway.
Old 1st December 2006, 08:57 PM   #6
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Not the easiest solution, but maybe a switching step down regulator?
Low losses, high regulation...
Old 2nd December 2006, 12:13 AM   #7
Minion is offline Minion  Canada
You could also try takeing a few turns off of the Transformers secondary windings to lower the voltages ???
Just a thought!!!
Old 2nd December 2006, 12:21 AM   #8
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Power Supply - need to reduce voltage - any hint?
Originally posted by deiksac
................. Once I saw a PS design using discrete transistors to reduce voltage ......................
that approach means lots of heat;
you must try other ways,one of them is already mentioned-can you unwound some turns from xformer?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd December 2006, 12:25 AM   #9
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I feel it would be easier fixing the broken channel than building a stable running high current regulator from scratch. What's wrong with it anyway?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 2nd December 2006, 07:19 PM   #10
unwinding turns from the transformer would make no sense as the healthy channel would have too low rails
re repairing the dead one - seems like there was some liquid in the amp, the pcb in the input part is burnt badly and eight transistors in the power part are gone, one repair guy (who is usually able o repair anything) returned the unit to me saying it is rather risky to repair it as the transistors are expensive and the amp quite complicated - lot of money could be spent for parts with no results. Maybe I should try another repair guy. The stupid thing is that alesis do not diclose amps schematics.
using monolithic regulators (such as LM338k) - dunno if they can take such big input voltage, afaik these are supposed to accept Vin about 40V, maybe I am wrong however thats why i asked for some discrete design, there is enoough cooling capacity in the amp. But it is not that elegant solution.
using chipamp designed to work with unbalanced rails does not sound that bad, just one of the rails will suffer heavier load so it may drop a bit in voltage which seems rather unwelcome to me
Power Supply - need to reduce voltage - any hint?Hide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
how to reduce PSU DC voltage space2000 Solid State 11 18th May 2008 10:12 AM
PS Problem: How do I Reduce Voltage? slor Power Supplies 7 27th April 2008 03:18 PM
How to reduce voltage from PSU?? oblerum Power Supplies 4 10th August 2006 07:04 AM
Reduce wallwart voltage argonrepublic Parts 2 19th February 2006 02:51 PM
