Cambridge Audio A3i Relay - Page 2 - diyAudio
Old 24th April 2008, 09:37 PM   #11
OXAUDIO is offline OXAUDIO  United Kingdom
Originally posted by x-pro
I've emailed you through the forum and on reply will send you the diagrams. Most likely the LED2 itself is at fault - just replace it first with a good quality green LED, lifting it at least 15 mm of the PCB. Mind the polarity! If it is the transistor (also possible, thought less likely) the correct type is ZVP3306A from Zetex, available from Farnell:
http://uk.farnell.com/9524851/semico...ZETEX-ZVP3306A
In 1996 I was working for Creek Audio and Michael was my boss . That does not change the fact that I've designed all electronics in that amp, including the PCB layout.
Cheers
Alex
I have now completed the repair to the A3i. LED2 was indeed faulty, and, having replaced it(with an orange LED incidentally- I didn't have any suitable green ones to hand), set the bias so that there is ca -1.2v at the collector of Q10, then test run the amp., first with no signal applied, for maybe 30 to 40 minutes, then for 2 or 3 hours continuously playing music of various types and at varoius volume settings, without any further problems.
Forgive my possible ignorance, but does the LED HAVE to be green? The orange one seems, so far, to be OK.
Old 24th April 2008, 09:58 PM   #12
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
Originally posted by homemodder
Hi X-pro
I would like to ask if you have spice models on the mosfets(zvp3306 or zvp3310). I tried using the models from zetex but they dont seem to work with lt spice.
Sorry, no, I don't have these models.
Good to know that the amp works. Green colour is important only because of the voltage drop on the LED. For green it is about 2V. On an orange LED the drop could be a bit less. Measure the difference - if it is only 100-150 mV than you probably can get away with this.
Cheers
Alex
Old 25th April 2008, 09:29 AM   #13
Thanks, Alex. Voltage is within those limits so far, but I'll get a few green LEDs just in case...
Old 2nd May 2009, 04:47 PM   #14
Talking cambridge audio A3i amp
Hi x-pro , very nice to read your post in forum . i am new ,so i can not email you in forum . could please send me full schematic to my email
eddyvu@hotmail.com . Thx.
Old 2nd May 2009, 05:08 PM   #15
x-pro's Avatar
Default Re: cambridge audio A3i amp
Done.
Alex
Old 19th April 2010, 09:53 PM   #16
merciiiiiiiiiiiii
Old 20th August 2011, 12:14 PM   #17
Hello X-Pro,
I have a cambridge Audio 3i which is genrating a lot of backgrounfd noise and wanted to know which potiential components would cause this to occur, can you plese send me a schematic of the amplifier as well. Thank you!
Old 25th September 2015, 10:12 PM   #18
hello dear friends
i am new here and i don t write english very well so excuse me if i make mistakes
i am from hungary and i buils a lot of hifi audio kit
and for the moment i buy from a car boot sale an cambridge a3i with a lot off faults
one channel works perfect
one channel give a hum like tunning radio stations
volume button doesen t close the volume totaly
on the pre board with the input connectors is a small green LED .it should be on?or off
here in this amplifier is off
i found the led 2 unsolder on the power board
i fix it ..still radio noise in speaker but the amplifier works loud but not clear and after 1 min or 30 sec relay click off and after on after 10 sec random
i change the capacitors with some denon 12000 up 63 volts
it s ok
what i should change there?
or somebody have time to fix it?
change all the components with good new components
contact me if someone is interested
here is my first amplifier build in 1987
very simple and sound greatif you make the voltage higher 50 volts you can get 80 watts per channel
simply great
thanks
waiting for an answer or solution
Cambridge Audio CD2 Sarion Digital Source 40 4th October 2014 11:33 AM
Cambridge Audio DAC-3 niiico Digital Source 9 14th January 2013 07:37 PM
R50 Cambridge Audio :) PhaseLockLoopy Multi-Way 2 27th May 2008 10:37 PM
Cambridge Audio 640C No audio output PLEASE HELP! Kajman Digital Source 3 10th December 2007 09:45 AM
cambridge audio cd 4se whats gan on Digital Source 46 3rd April 2007 10:13 AM
Copyright 1999-2017 diyAudio
