Problems with Carvin PB500 Amp
Old 29th November 2006, 04:02 AM   #1
Thack is offline Thack  United States
Default Problems with Carvin PB500 Amp
I'm having problems with this amp. I replaced the main MOSFETs with IRFP240/IRFP9240. I found that I don't have -15v past R108. The resistor is hot to the touch and loses -5v. At R58 and R8 It's down to -10v and past them it's down to -5v. So what is draining my voltage. Could Q1 and Q51 be the problem? This site wont let me upload the schematic so I have to show the link instead.
http://www.carvinmuseum.com/pdf/proa...owermodule.pdf
Old 30th November 2006, 12:33 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
First,you have to disconnect the DC15V rail from the load(ie the power amp and the protection).See the voltage go normal or not.
Old 30th November 2006, 01:59 AM   #3
Yes, when I take the 15v leads(QC3 & QC4) from the transformer off the board they meausure 15v but it is alt. voltage. The diodes d101 thru d108 make the voltage DC. The -v drops -5v right after R108 and it gets hot to the touch. could P101 be the problem. It looks like it balances the voltage to the IC 102A (Realy Threshold)
Old 1st December 2006, 01:21 AM   #4
Leolabs's Avatar
No.That's the wrong way to tackle the problem.You should disconnect H1-3,+15V,H1-4,-15V,H1-5 from the power amp section and protection circuitry.
Old 1st December 2006, 02:44 AM   #5
Those are all on a connector that's 10 pins long. I can't isolate individual pins. Should I take the whole harness off? H1-5 & H1-3 do measure 15V.
I took off the whole harness and the voltage drops are still there. There must be a circuit or semiconductor that is draining the voltage. Like I said earlier there is a 5v drop on the negative side thru R108 and it's only a 22 ohm resistor. Something downstream of the -15V rail is draining the voltage. Any ideas?
I called up Carvin and they won't fix it. They said it's too hard to get parts considering it's 15 years old.
Old 1st December 2006, 01:59 PM   #6
Leolabs's Avatar
Ok.Definitely problem with the loads.Try to desolder all the OPAMPs from the board and check the voltages again.If things getting normal,then 1 of the OPAMPs are damaged.If not,maybe problem with the bias stages.
Old 1st December 2006, 10:08 PM   #7
thanks for your help. Is there a way I can check the chip with an volt meter and chip specs to determine if a ground is present where it shouldn't be? Those chips are surface mounts and look difficult to remove.
Old 2nd December 2006, 12:33 AM   #8
Leolabs's Avatar
Because something is 'loading' the voltage rail and don't know who is the culprit.All the suspected components should be removed to determine which is the problem here.
Old 5th December 2006, 02:36 PM   #9
Update: I just realized my output voltage at the speaker output is maxed out at +70V. Somehow my input stage is getting voltage to turn on the mosfets. I also measured +40 at A2 IC pin #2. The max input voltage for that chip is +/-18V. So I have some problems. I suspect a diode somewhere has failed and is letting some of the high rail voltage (70V) get to my input stage.
Old 6th December 2006, 12:34 AM   #10
Leolabs's Avatar
Possibly the MPSW42/92s already shorted.You can measure them with a diode test function on a DMM.
Problems with Carvin PB500 AmpHide this!Advertise here!
carvin x-100B engel dela pena Instruments and Amps 4 12th October 2007 12:47 PM
wtb Carvin v3 amplifier gemm012 Swap Meet 1 11th December 2006 03:01 PM
Carvin HT1000 problems rkc7 Solid State 3 20th November 2006 10:27 PM
REQ: Schematic for Carvin DCA 800 Bargainhunter Solid State 1 1st March 2005 02:47 AM
Carvin DCA 800, only NPN? cm961 Solid State 5 24th October 2002 03:34 AM
Copyright ©1999-2017 diyAudio
