Old 29th November 2006, 12:53 PM   #11
sam9 is offline sam9  United States
sam9's Avatar
It's also bad advice to recommend use of 2SA1302/2SC3281 as these are the worlds most faked transistors, and went obsolete years ago with the advent of their replacement 2SA1943/2SC5200.
Sadly, 2SA1943/2SC5200 are also subject to fakes. I had a number of them until I figured out what was wrong. The best protection is to buy from a reliable source. Digikey is an example.
Old 29th November 2006, 02:55 PM   #12
pooge is offline pooge  United States
Originally posted by jacco vermeulen
Who said the statement is correct ?
Car talk,..again:
Consider the tires as the output devices.
The size of the car determines the engine horsepower, see the vehicle as the loudspeakers.
The engine torque determines the size of the tires.
The steering response should always be faster than the car, otherwise the car will run off the road.
Going through a corner, the steering will have to turn into the corner more than the direction the car is going to, difference between steering direction and car direction is the phase shift, the phase margin is what is left before the tires start to slide. The nominal contact surface of the tire remains the same, but the effective surface at higher steering versus car direction angles is reduced.
The higher the speed of the car, the greater the difference between steering and driving direction.
At the tire/car critical speed point (angle speed) the gas should be reduced or the brakes hit or the tires loose grip and the car crashes. Maximum allowable phase shift is reached, hitting the brakes reduces the speed=> freq. limiting
Replace the tires with faster ones, and the angle between steering and the driving direction of the car is reduced at the same speed because the raised grip of the tires makes the car respond faster.
=> sustained hFe value at higher frequencies.
Bigger tires allow for a bigger car, but in general bigger tires mean less cornering grip.
Putting racing tires on an Edsel doesn't make it a thoroughbred, but it generally doesn't make the car drive worse. That does not mean the tires will not have problems with the camber and so on of the wheel suspension geometry/type.
This gets a big HUH???
Old 29th November 2006, 03:02 PM   #13
I did.
Car talk,..again:
Well Jacco, I thought I knew a lot about car suspension and a little bit about electronics, but this is beyond my comprehension.
That is not an invitation to try the analogy again!
Old 29th November 2006, 03:10 PM   #14
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Let me rephrase: a correct statement instead of the one in post 2 and post 5 is:
it's easier to replace by faster devices than slower ones !
How's about an analogy with sea wave spectra, Joe Fourier transformation, Nyquist criterium and critical wave height ?
Not so much,.......if it says "ZM" in the corner.
Old 29th November 2006, 03:27 PM   #15
Originally posted by pooge
post 7:
If the amp is compensated for a lower ft transistor, why would substitution of a higher ft transistor cause instability? It should have a higher phase margin.
post14:
The correct statement is:
Please explain the difference between the statements and why post 14 is more accurate.
Old 29th November 2006, 03:37 PM   #16
See No14 above, i was not questioning the one by Pooge.
Old 29th November 2006, 04:13 PM   #17
Hi Jacco & Pooge,
does this mean we are agreed? That substituting a faster output device (within sensible limits) but retaining all the other physical attributes of a circuit should not increase the risk of instability (i.e. reduced phase margin).
To all others.
Why do so many commentators state that changing to a faster device holds the risk of instability?
Old 29th November 2006, 04:48 PM   #18
In the Hitachi days the main theme was how to keep them from swinging, because they were so fast and susceptible to even a minor change of wiring. Funny stuff in the PS, and the beasts oscillated. Vibration problems are my analogy for those lateral things.
Lack of fast enough output devices create design issues, leading to various compensation measures, which then are only a compromise.(imo)
The availability of faster ones makes it easier on the amp circuitry, easier to design a good amplifier.(audio designers words, not mine) In turn, the same problems arise as in the J50/k135 days. Such as direct wired output devices: good enough for Dino 15003s but not for 60MHz Sanken devices, and stuff like the mentioned parasitic capacitances, board layout, powersupply issues, grounding, yes or no ground planes, wiring, etc. Someone who has been playing with TO3 Hitachi's in the past finds spaghetti amps pretty painfull to watch.
If all those amplifiers in need of an output stage swap were designed as high speed switching amps, with 4-layer teflon boards and the works, stepping up to higher Ft devices wouldn't be a big deal i suppose.
Recall the ever continuing debate on where exactly to place snubbers/ bypass capacitors, and which value is allowed ? Many older amplifiers, and maybe (some) recent, nowadays are seen as having a lot of flaws.
On the ksa i used some of the most fast devices around instead of the original slow ones, and had no problem getting the amps stable. Just lucky maybe, it does show that the raised finger is somewhat uncalled for.
Read Jozua's post of the Aalt-Jouk interconnect switch effect ? If it were all that easy it would swiftly be an extremely boring merry go round.
old RCA transistors- what are they? needtubes Parts 13 23rd July 2012 09:43 PM
what transistors to use? prorms Solid State 1 20th November 2006 05:14 PM
Best transistors YUTK Solid State 1 20th May 2005 04:16 PM
transistors Dj BASS AMP Solid State 1 31st March 2003 04:46 PM
transistors lemondog Swap Meet 5 1st March 2002 07:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
