I've built a simple stereo amp using LM3886's. There's two LM3886's bridged on each channel. The power supply is built from a Plitron 2x22VAC 400VA transformer and 60,000 µF of capacitance for each channel. When I input an audio source in one channel, everything is fine and the sound is pretty good. However, when both channels are hooked to the audio source, the sound looses all its bass and depth. What the hell is going on? I don't think that's the kind of problem caused by a ground loop and I strongly believe there's enough power in this amp to supply the two channels. Below is a picture of the problem. Note that the board in the lower left corner was a regulation board...I converted it to a 'do nothing' board. It already had the bridge and connectors for the transformer so I thought it could still be useful. Any help appreciated, Gabriel |
#2 |
Are you sure that you don't have the phase reversed in one channel? That would make the bass go away. That would be easy to do with a bridged amp. Just try reversing the speaker connection on one channel. If that fixes it that's the problem.
Later Bruce PS: Nice looking amp. Good job.
What ever makes the tunes flow |
#3 |
#4 |
Another thing that bugs me is a little buzzzzzz when no music is played (not loud enough to be heard when music is playing).
When the volume pot is at one end or the other, the buzz is as loud as it can be. On the other hand, when the pot is centered the buzz is almost absent. I'm sure this is not a big deal, but I'm lacking experience to solve it by myself. Help appreciated. regards, Gabriel |
#5 |
Banned
Why so many capacitors?? :P lol..
#6 |
when i have had this problem it has been from a Ground loop or Instability in the Amp. My first recomendation is put a series resistor of about 2k between the Amp's input and the Pot's wiper, if no effect then a pair of 10 ohm resistors between each RCA jack's ground and the ground wire going to the Amp Board. make sure that the RCA jacks are insulated from the Chassis with washers. (real Importent). BTY what circuit did you use for the Bridge LM-3886 Amp?
#7 | |
Banned
#8 |
ppl, I'll try what you say...thanks.
#9 |
hopfully it will work good for you, also it looks like your wire routing has all the Power,Input and output wires running paralell to each other try puting the input at Right angle to the others and separating them. Good Luck
also see the assembly manual to the PM21 at http://www.marchandelec.com/articles.htm this is a pdf file on there Kit containing two LM-3886 |
#10 | |
The LM3886 is just a powerful opamp. Simply design one LM3886 as a non-inverting amp with a certain gain, and then design another LM3886 as inverting with the same gain. The output of the non-inverting is the +ve to your speaker, the inverting is the -ve. Easy. Beware, you cannot power 4ohm loads with 2 bridged LM3886s as the overcurrent protection on the IC will cut in and clip the signal. You can however, use 4 LM3886s in bridge/parallel to power 4 and 2 ohm loads. And Gabster... yes, why so many smoothing caps? The LM3886 has quite a high PSRR, all those caps are not needed. If you experiment enough, bridged LM3886s can give a lot of power. I got 220WRMS into 8ohms @ 1kHz with under 0.08% THD+N out of mine! It had 8 channels (that 16 LM3886s) powered by 2x500VA 30-0-30 torids that was all mounted in a 3U 19" rack mount case. This is it: |
| RCA: Stereo to Mono? | silentblackhat | Car Audio | 13 | 20th October 2007 05:06 AM |
| mono vs. stereo | schmalex | Chip Amps | 1 | 6th June 2005 02:51 PM |
| Stereo vs Mono | profuse007 | Car Audio | 4 | 6th March 2005 09:25 PM |
| stereo to mono | janey | Solid State | 3 | 12th December 2001 06:57 AM |
| Page generated in 0.11119 seconds (81.12% PHP - 18.88% MySQL) with 11 queries |
