Hi all.Need any improvement on this design???
#2 |
If you want to do sometihing like that I would change a few things.
I would probably run an OPA604 off a ±24V regulated supply. |
#3 | |
I think that circuit will work good, Leolabs. What we don't know is BIAS in output transistors. Could be anything from 80mA - 2000mA. NE5534 will work good at +-19 Volt (absolute max = +-20). NE5534, I guess, at +-15V would have an max output swing of like +-11-12 Volt peak. (The datasheet will tell if this is correct.) This should give max power for this circuit: 8 Ohm: 7.5-9 W RMS 4 Ohm: 15-18 W RMS ================================= your circuit is an excellent and simple way to build a REAL HiFi amplifier with moderate output power I have built a similar long ago, using NE5534 + Bipolar in Class A with 2x12 Volt Transformer. It has got a very good sound. lineup
lineup |
#4 |
the limiting voltage from the output is set by the voltage from the opamp. This in turn is {Vzener-VopampLoss}. For +-15Vrails, your Vout will be <10Vrms Run the opamp as high as the datasheet will allow less a margin for reliability. (?+-20.5Vdc!) The FETs shown are obsolete. Try 2sk1058/j162 1057/161 1056/160 or Exicon ec10n16/p16 ec10n20/p20 or Renasis equivalents. Why fit the compensation cap 5 to 8? You are not running unity gain.
regards Andrew T. |
#5 |
Leo,
perhaps some capacitor over each resistor R7 and R8, or else they are part of the gate resistor. Cheers Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#6 |
Many many thanks guys!I m not concern much about output power/efficiency,but stability and sound quality.
Regarding the Cc issue,can it be omitted??? And the LATFETs,I do have them. |
#7 |
Cc?
You mean my suggestion? 100 Ohm gate resistance is better than 570 Ohm, actually MUCH better! Use at least 1 uF plastics over each R, by frequency they come into play very well as FET's input are capacitive. You also save some job for the feedback component, eg. your op-amp which should be hopefully equal with better sound, perhaps.. Cheers Michael
#8 | |
Also the compensation cap,can it be omitted too??? |
#9 |
Just to be polite and replying to your post, I don't know!
You mean that small 22 pF for the op-amp, I have not seen the datasheet, but I would be carefull and read what it says if there is such an option for an op-amp. Cheers Michael
#10 |
Actually, the NE5534 has an absolute max supply voltage of +/-22V and will run happily at +/-20V. So, you can up the zeners to 20V parts, up the supply rails a little, and gain some output swing.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
| Sound Improvement! | Tripmaster | Chip Amps | 27 | 1st July 2008 08:48 AM |
| SBLive improvement | p2mine | Digital Source | 25 | 23rd July 2004 07:21 PM |
| Can anyone suggest a design? | jasonb84 | Multi-Way | 27 | 28th April 2004 11:49 PM |
| Symm-Amp Improvement | tab30 | Solid State | 8 | 23rd April 2004 12:09 PM |
| suggestions for improvement | wintermute | Solid State | 12 | 10th September 2003 02:52 AM |
| Page generated in 0.15373 seconds (64.97% PHP - 35.03% MySQL) with 11 queries |
