C-Audio RA2000 Protection LED - Page 4 - diyAudio
Old 6th November 2011, 11:22 PM   #31
Normally the protection relay is to protect the speaker in case of one of the output transistors shorted or failed. This is because the speaker are connected directly to the output transistors. Suggestion power the amplifier and check the voltage before the speaker relay contact. If you read a neg/pos high voltage means that's ones of the output transistor it is leaking. If the voltage is high the relay will enable disconnecting the speakers. Sometime power transistors will check OKAY statically but when they are put under power they failed.
Old 7th November 2011, 06:45 AM   #32
east electronics's Avatar
there is an 1K resistor that goes open and if it does protection stays on for no other obvious reason .... been repairing this twice so far in RA 2000 but never though of writing down the part number ...
only i remember is that resistor is located on the rear area of the amp and if try to measure on board can confuse you
regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Audio protection circuit for microprocessor ADC? Neil_J Digital Source 1 26th June 2007 07:33 PM
over-temperature protection for audio smps zilog Power Supplies 5 19th January 2007 01:51 AM
Planet Audio PA4004 protection problem dre0011 Car Audio 7 20th November 2006 11:24 PM
troubleshooting pwr protection, car audio amp masterchief Solid State 11 10th September 2006 12:26 PM
Over-current protection in Audio IC Output Buffers ppl Solid State 1 21st October 2003 06:35 AM
Copyright 1999-2017 diyAudio
