10W JFET/MOSFET SE Class A, no Feed Back
Old 21st November 2006, 02:52 PM   #1
widowmaker is offline widowmaker  Europe
widowmaker's Avatar
Send a message via ICQ to widowmaker
Default 10W JFET/MOSFET SE Class A, no Feed Back
This is my new project:
1st stage - common source (2SJ103BL), 2nd - source follower (2SK170BL), power stage - common source with current source load (2SK159 & 2SJ200), no feedback, no input or output caps...
High Tension Wires Department
Daniel Petrov also known as widowmaker
Old 21st November 2006, 02:59 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Thumbs up Nice!
Nice widowmaker!
Good to see you posting a project again.
They are usually very interesting, to me.
your friend
lineup
lineup
Old 21st November 2006, 03:01 PM   #3
widowmaker's Avatar
10x, Lineup!
More info about this project will coming soon
AgTa cap is russian military production, 1000uF/6V. I think thas is better choice than Black Gate cap...
Old 24th November 2006, 02:25 PM   #4
widowmaker's Avatar
I made some changes on this project.
The schematic bocomes more simplified...
Now the servo has only opamp and few caps and resistors.
bypassing (by quality cap) the source resistor on first stage is good enough to eliminate noises from opamp...
Old 25th November 2006, 02:27 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Nice to see another minimalist MOSFET amp.
Old 25th November 2006, 07:35 AM   #6
bikehorn is offline bikehorn  Canada
bikehorn's Avatar
interesting, have you built a prototype? what kind of PS would be ideal? i have always wanted to try a capacitance multiplier.
Old 25th November 2006, 04:05 PM   #7
widowmaker's Avatar
I think that PS with CLC filters (one for each rail) is good enough.
for example:
47mF/3mH(3.5A, iron core)/47-100mF
New, modified schematic coming soon
Old 25th November 2006, 09:38 PM   #8
bikehorn's Avatar
i have always been interested in CLC filters but i can't ever find any Ls of the right type for a price i would remotely consider paying....what about just lots of capacitance, Krell style? or full on regulation? i have read that regulators introduce a triangular waveform into the rail while capacitance multipliers come very close to full regulation while avoiding the triangular waveform. is this true, or of consequence?
Old 26th November 2006, 01:46 PM   #9
Neon_Knight is offline Neon_Knight  Bulgaria
Neon_Knight's Avatar
Another great construction from Widowmaker
Old 26th November 2006, 02:00 PM   #10
lineup's Avatar
for example:
Have a look at my effective C-R-C-R-C-R-C.
This time I used resistors:
0.10 - 0.22 - 0.33 Ohm
and capacitors:
4700 - 4700 - 10.000 - 10.000 uF
Result:
Very Good effective Power Supply filtering.
Almost no ripple for 2 A constant current.
In Multisim.
The drop of 1.3 Volt I can live with, because
so much easier to find some power resistors 0.10 - 0.33 Ohm
than winding your coils or try to find and buy such
Have a setup of 0.10 - 0.47 Ohm (2-5 Watt) resistors at home
as well as a supply of 4.700uF / 10.000uF supply caps
.. and you will put together a nice low ripple power supply very quickly
whenever you get an idea you want to try.
lineup
See my Very Clean Supply in Attachment
here
lineup
10W JFET/MOSFET SE Class A, no Feed BackHide this!Advertise here!
neg feed back into v/slope stereo 2 pre-amp pointy Tubes / Valves 0 17th March 2009 12:29 AM
Feed-back class D mgm2000ro Class D 5 5th July 2008 08:29 PM
Length of feed back resisitor in NIGC 100db Chip Amps 2 24th February 2006 03:03 AM
Preamp Schematic I Found On The Web. Feed Back Wanted. LJOE1969 Instruments and Amps 5 29th August 2005 06:53 PM
Current feed back again.............. ashok Solid State 0 15th November 2004 07:54 AM
