Old 26th December 2002, 01:55 PM   #1
hacknet is offline hacknet  Singapore
Default computer psu
how do you start a ATX com psu?
i have tried shorting the pwrON to gnd while pwrOK is shorted to 5v....
what else do i have to do?
Old 26th December 2002, 11:41 PM   #2
Banned
Send a message via MSN to SkinnyBoy
you don't connect power ok/power good to anything... you should just be able to connect the power on (Green, pin 14) to ground... if that doesn't work, try connecting a load to teh powersupply as well, such as an old harddrive..
Old 27th December 2002, 01:00 AM   #3
Warp Engineer
On Holiday
AudioFreak's Avatar
1) Power_good is just a monitoring signal normally used by the motherboard to ensure the quality of the power, leave it disconnected.
2) Always provide a load on the +5V line testing without one can destroy the psu in a very short period of time. A small load on +12V is also a very good idea.
3) Short power_on to ground.
Old 27th December 2002, 01:27 AM   #4
the voltage shoots up to 13.39v be4 dropping to 0.2v... and reason for this?
Old 27th December 2002, 04:23 AM   #5
Banned
Umm..... what voltages??
Old 27th December 2002, 05:02 PM   #6
this is for the 12v rails...
Old 27th December 2002, 10:10 PM   #7
Banned
Well, have you tried the powersupply with a load on it??
Old 27th December 2002, 10:21 PM   #8
Circlotron's Avatar
Probably shutting down on overvoltage because there is no load. PC supplies being what they are, have only the least amount of parts to function so sometimes they will act strangely without a load. Definitely use a small load on each rail.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 27th December 2002, 10:25 PM   #9
Banned
Are you just repeating everything I say???
Old 28th December 2002, 12:06 AM   #10
Circlotron's Avatar
I never say anything unless you have authenticated it by saying it first. You are my guiding light.
Anyone looking for a computer? corryn00 Swap Meet 0 28th January 2005 04:16 AM
OBs for computer miguel2 Multi-Way 7 25th February 2004 09:20 AM
computer sub Opie Multi-Way 1 22nd November 2002 01:25 AM
Page generated in 0.16694 seconds (47.07% PHP - 52.93% MySQL) with 10 queries
