what transistors to use?
Old 26th November 2006, 05:46 PM   #11
dshortt9 is offline dshortt9  United States
dshortt9's Avatar
Here is an interesting article describing the VI limiting circuit.
http://sound.westhost.com/vi.htm
Old 30th November 2006, 12:36 AM   #12
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default ...
so witch transistor would suggest for this section of amp?
Old 30th November 2006, 01:33 AM   #13
ReidK is offline ReidK  United States
Teemuk, since this $%^&* won't even acknowledge your work, I'll say "Thank you". I found it very helpful.
Reid
Old 30th November 2006, 03:52 AM   #14
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Default Re: ...
See posts 2,4,5 and 11 for your answer - they all say the same thing: use the BC546/BC556 as shown. Any grade would be fine They are just a few cents at Mouser, why torment yourself over it?I also have a bunch of BC546C and BC556C, of which I would be happy to sell you up to 4,000 of each. Since you'll probably find many of your other parts at Mouser (once you figure out appropriate values) that likely makes more sense.
Old 30th November 2006, 08:15 AM   #15
K-amps is offline K-amps  United States
K-amps's Avatar
Default Re: Re: ...
Originally posted by BobEllis
.... of which I would be happy to sell you up to 4,000 of each. Since you'll probably find many of your other parts at Mouser (once you figure out appropriate values) that likely makes more sense.
4000?
Were you planning to make an output stage with them...
Old 30th November 2006, 08:17 AM   #16
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
No,
Bob is badder than most.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 30th November 2006, 10:01 AM   #17
No,
Bob thought that by buying up the world stock of C grade he could prevent all the rest of us from building any decent front ends for our amps.
His ploy failed when he offered them as part of a group buy for the benefit of our community.
It did stop all the others from improving their front ends!
regards Andrew T.
Old 30th November 2006, 10:22 AM   #18
BobEllis's Avatar
Default Re: Re: Re: ...
Originally posted by K-amps
4000?
Nah. That's just what happens when you commit to a group buy design and the distributor runs out. For a couple of months the minimum buy quantity was 10,000 of each. I've managed to unload a few of the 9,500 extras, even used a few myself.
Old 30th November 2006, 10:25 AM   #19
K-amps's Avatar
Well bless you and all the guys that make life for the rest of us easier !
Old 30th November 2006, 10:41 AM   #20
BobEllis's Avatar
Thanks K - your supply of MJ21195 and 96 have made life easier for a few of us, too.
what transistors to use?Hide this!Advertise here!
old RCA transistors- what are they? needtubes Parts 13 23rd July 2012 10:43 PM
what transistors to use? prorms Solid State 1 20th November 2006 06:14 PM
Best transistors YUTK Solid State 1 20th May 2005 05:16 PM
transistors Dj BASS AMP Solid State 1 31st March 2003 05:46 PM
transistors lemondog Swap Meet 5 1st March 2002 08:05 PM
