Old 20th November 2006, 03:56 PM   #1
FastEddy's Avatar
Default Interesting new TI op-amp w/ very low noise
http://www.ti.com/corp/docs/landing/...eet+PR+sc06209
Check out the OPA827 op-amp = JFET input with 4.5 nanoVolt noise, split rail supply to +/- 18 VDC ... seems ideal as a input front end to power amps, balanced (XRL) to unbalanced (RCA) converter, active filters or EQ, A/D driver &/or DAC output buffer ... ( two channel, 8-pin = OPA2827 , although I would stick to the '827 for best CMRR between channels )
( http://focus.ti.com/docs/prod/folders/print/opa827.html [check out all those software tools at bottom of page!]... http://focus.ti.com/lit/ds/symlink/opa827.pdf ... this stuff keeps getting better and better ... )
Old 21st November 2006, 12:46 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
4.5nV??? i think there are others which are better than that.
Old 21st November 2006, 08:14 PM   #3
dpaton is offline dpaton  United States
Send a message via AIM to dpaton
The recently previewed OPA211 comes to mind...
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
interesting amp & interesting problem m6tt Tubes / Valves 9 14th August 2007 06:28 PM
FS: Capacitors/ Opamps/ Power Transistors/Noise Filters & Other Interesting Stuff dtm1962 Swap Meet 1 8th February 2006 04:21 PM
interesting noise!!! nbcd Solid State 1 13th October 2003 08:12 AM
Interesting app note on JFET noise TheFettler Solid State 8 19th September 2002 02:02 PM
Page generated in 0.37724 seconds (17.43% PHP - 82.57% MySQL) with 10 queries
