50watt into 1ohm load with KAPPA 9
Old 20th November 2006, 01:12 PM   #1
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Default 50watt into 1ohm load with KAPPA 9
Does anyone remember SONNY discussing his MIRAND amp on this forum ?
I have made mono amps version with less output and stronger transistors, supply is about +/-30V, 500w trafos and a single pair "average" 15.000uf (Jensen) and switchdiodes, bias is 29mv and has needed adjustment from time to time, but seems to have settled now, it affects sound and must be very accurate
It has been playing quite a while now, and a friend who liked it asked if we could test it on his speakers - KAPPA 9
He has tried a lot of amps without much luck, but found a old PS.Audio, and at the moment he is is using a cheap NAD 60watt, anything else have failed
SURPRISE !
At start I was a bit nervous being told that KAPPA 9 impedance can drop below 1ohm
SOUND was impressive right away, and we could hear this was something special
And amps didnt even get hot, even at loud levels - very impressive
KAPPA 9 has a bass servo, which my friend didnt use because his amps couldnt drive it
But we heard instantly that sound improved a lot with bass servo
But NOW amps got hot, but not too much, and they didnt get any hotter even when driven into clipping
Unexpectedly we could play pretty loud, but ofcourse not insanely loud
What surpised me the most was the quality of sound - I have always thought that amps would sound better if driven into 8ohm load
And this was into 1ohm load, and propably strange phase angles
At all times music was presented with unbelieveable ease, liquid and airy
MIND YOU, this is done with a single pair of transistors - I find that pretty amazing - it should be able to drive a ribbon with VERY low impedance - just what I have been looking fore !
Old 20th November 2006, 03:27 PM   #2
lineup is online now lineup  Sweden
lineup's Avatar
Default Re: 50watt into 1ohm load with KAPPA 9
Standard edition
Q1 MJL3281A
Q2 MJE15030
Q3 2SC2911
Q4 MJE15031
Q5 MJL1302A
Q6 2SA1209
TOPIC diyAudio: http://www.diyaudio.com/forums/showt...496#post324496
Sonnya Website: http://mirand.dk/index.html
Brochure, Data: http://mirand.dk/brochure-miranda1v11.pdf
Schematic PDF: http://mirand.dk/miranda1v11.pdf
lineup
lineup
Old 20th November 2006, 04:16 PM   #3
I am not sure if Sonny is active at the moment
Old 20th November 2006, 04:19 PM   #4
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The Extended position, your "bass servo" , is where the K9 dips to 0.8 Ohms.
Unless my memorybank is ready to be flushed down the drain, the "common" budget power amplifier for the Canine was an HK Citation 22.
Buttugly, nevertheless a $2000 power amplifier in the Infinity K9 years. And to make the K9 sound really good was to go bi-amping.
Maybe your miracle amp can survive the K9s with the Extended bass switched Off.
I can also understand you can get a moderate volume out of loudspeakers that can blow the roof off your home with the proper set of power amps.
But getting a decent volume out of the Infinity's with only a single pair of output devices and 30Vdc rails ?
Stronger transistors ?
In Extended mode the K9 was called the AmpKiller
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 20th November 2006, 04:43 PM   #5
Clarification,
Amps did survive with K9 in extended bass mode, and that was over hours of listening at VERY high volume levels close to clipping
And it did not only survive, but sounded absolutely amazing - although I dont like the K9 it was pretty impressive - music had magic even at high levels
Furthermore the amps was driven at clipping levels fore a while with no other problem that distortion, but no exscessive heat at all
BTW, I should mention that amps has enough cooling to be driven in class-A
Old 20th November 2006, 04:45 PM   #6
R.I.P.
I wonder if two pair of Krell 50Klone monoblocks could match or better that single pair of 3281/1302s?
You'll need to borrow 2pair and tell us.
regards Andrew T.
Old 20th November 2006, 05:25 PM   #7
I expect that I have to build amps to my friend and his beloved K9
They will probably be with some 300watt modules - BUT with lower voltage rails to do about 100watt
Old 20th November 2006, 06:31 PM   #8
Tinitus,
Reads as a good example of how much 1 pair of output devices is capable of if they have plenty of cooling, thanks.
Your friend should try to find one of those Infinity boxes for bi-amping
Old 20th November 2006, 06:59 PM   #9
Biamping would be fine - But what do you mean by "infinity boxes"?
His K9 are the original with emit tweeters
I think they are with double speaker terminals for biamping
Old 20th November 2006, 07:44 PM   #10
Infinity crossovers for the RS series are still very frequently for sale.
Not the very best electronic crossovers, but i bet it beats the standard filter setup of the classic Kappa 9 for bi-amp mode, and they're cheap.
50watt into 1ohm load with KAPPA 9Hide this!Advertise here!
tubes: Jcm 900 Slx 50watt Stongelo Instruments and Amps 1 9th December 2005 09:32 AM
Kicker DX700 classD; how can it drive a 1ohm load? SHOdown Class D 42 8th February 2005 12:22 AM
50watt 8 inch driver question psychosteve Multi-Way 0 24th September 2004 12:02 PM
50watt Plexi Again edsmith Tubes / Valves 2 23rd March 2004 07:14 PM
