Amplifier Advice
Amplifier Advice
Old 26th December 2002, 06:05 AM   #1
fr0st is offline fr0st
Default Amplifier Advice
I know newb threads are anoying ..... but..
I've recently made a 25w x2 amp based on the LM1875 chip (Elliot design) just as a first off project.
My speakers arn't quite audiophile but are resonable enought to warrant a better amplifier to get more out of them.
there 30w nominal 8 ohms speakers, 92db@1m/1w
Can anyone you recommend a Class A design to accomodate them?
I've looked into the Zen v4 and it may be an option bridging them but distorion will be more prominate since each wil lget a 4 ohms load.
Thanks for your time
fr0st
Old 26th December 2002, 07:05 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
newb threds are not annoying there good because every one in this world has to learn and start at some point right. Welcome. I garentee your going to learn lots here. : O )
J'
Old 26th December 2002, 01:11 PM   #3
paulb is offline paulb  Canada
Default Re: Amplifier Advice
Is your system loud enough now?
ZenV4 is a good choice. You can always build just two channels (not bridged), then add another set later.
You might also look at the JLH 10W - there's a higher power variant on Geoff Moss's website - see this thread:
http://www.diyaudio.com/forums/showt...&highlight=JLH
Rod Elliot's DoZ is a similar design.
Old 26th December 2002, 01:23 PM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
You can extract the very best out of your gainlone before embarking on more ambitious projects. There is room for improvement in the sound of what you have, why not try to better it? Look at what Peter Daniel has created, read all on
http://pub4.ezboard.com/ffakeidsfrm1
If you have questions ask them here or on the AmpChip board.
cheers
peter
Old 28th December 2002, 12:06 PM   #5
I never thought mine was a gainclone.... Al lthe ones i've seen are LM3876 based. Does the Class A mod work with both chips?
Old 28th December 2002, 12:35 PM   #6
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Amplifier Advice
Hi fr0st, and welcome
The LM3875 and LM1875 are fundamentally the same, apart from packaging and power differences, so any circuit will work for both. The LM 3876 is sometimes used as a gainclone, but does not perform as well as the other two, I found it sounded compressed, a bit like an FM radio Rock and Pop station.
I recomend trying Thorstens inverted circuit first, before you think of building something new. Even with off the shelf components it sounds better than many other amps.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Amplifier AdviceHide this!Advertise here!
Advice on new amplifier j.videtich Solid State 6 4th April 2008 01:28 AM
Pocket headphone amplifier advice ?? Dxvideo Headphone Systems 25 31st December 2007 03:11 PM
Seeking amplifier kit advice which 1 to build? Stu_M Solid State 19 29th September 2007 12:09 PM
Need some amplifier advice Fast1one Solid State 5 24th January 2007 05:16 PM
Advice on amplifier for tweeters opp Multi-Way 7 27th September 2005 08:56 AM
