Old 18th November 2006, 06:28 PM   #1
roger-k is offline roger-k  Norway
Default A question about powersupply fuses?
I want to make a powersupply, for a preamp. (look at the attachment)
Are the fuses F1 an F2 necessary or is it enough with just a fuse at the primary-side of the transformer?
Roger
Old 18th November 2006, 07:21 PM   #2
XEAGLEKEEPER's Avatar
If the bridge rectifier shorts they(F1orF2) will open the secondary circuit and prevent your transformer from burning-up cheap insurance.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 18th November 2006, 07:27 PM   #3
lgabco is offline lgabco  Slovakia
Fuses F3 and F4 are not necessary. F1 and F2 are enough.
Old 18th November 2006, 07:58 PM   #4
OK. Thank you very much for the answers.
Roger
Old 19th November 2006, 10:05 AM   #5
Hmm.... but....
If I do nat have F1 and F2. What will happen if I get a short-circuit in one of the diodes (or the rectifyer).
Will not the fuse at the primary-side (process side) of the transformer blow, before the transformer is getting damaged?
Roger
Old 19th November 2006, 10:17 AM   #6
Which is size of transformer ?
Old 19th November 2006, 10:30 AM   #7
F3 & F4 kill the source impedance of the PSU.
move then to between C3 and C5 and between C4 and C6.
The primary fuse IF CLOSE RATED can be used for effective transformer shutdown if the output goes wrong.
Fusing does not protect any internal components.
They are there to stop the house catching fire.
DO NOT fuse the mains neutral, only fuse the mains live connection to the transformer.
Operating VA/supply voltage = operating current= close rated fuse.
Use a T rated fuse (anti-surge) to allow switch on and short term transients.
regards Andrew T.
Old 19th November 2006, 01:30 PM   #8
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by AndrewT
F3 & F4 ....
move them to between C3 and C5 and between C4 and C6.
quite right!
Best place is AFTER the first Big Filter Capacitors.
If placed before these Electrolytics, then fuses might blow
if and when electrolytics are charged by high inrush currents at Startup.
As already told,
place before regulation will not disturb the clean output of regulator.
lineup
powersupply design question casiomax Chip Amps 88 1st September 2008 09:15 AM
question on fuses Antonix Solid State 8 13th October 2005 02:52 PM
Aleph powersupply design question kasra Pass Labs 12 11th June 2002 05:47 AM
basic question : reduce amps supplied by powersupply fezz Solid State 0 26th March 2002 08:58 PM
Aleph 2 LC powersupply ...question.. hifi Pass Labs 16 3rd February 2002 05:27 PM
Page generated in 0.61585 seconds (13.85% PHP - 86.15% MySQL) with 11 queries
