Help me design a pcb for redcircuits  10 watt amp..
Old 18th November 2006, 04:25 PM   #1
rajagopal87 is offline rajagopal87  India
Default Help me design a pcb for redcircuits 10 watt amp..
I am no good in pcb designing and I want a layout for the below amp...
http://www.redcircuits.com/Page61.htm
If anyone knows how to design a good pcb Please make one for me..
Thank You.
Old 1st March 2007, 05:55 AM   #2
gni is offline gni  United States
gni's Avatar
http://sound.westhost.com/
hobbytron
Old 1st March 2007, 06:25 AM   #3
TomWaits is offline TomWaits  Canada
TomWaits's Avatar
Default Re: Help me design a pcb for redcircuits 10 watt amp..
I think you would have much better results building a LM388X gainclone or perhaps even better this amp! Are you restricted to the small rail voltage supply? If not you could build something better that remains in a small footprint with ready available artwork to etch your own PCB's?
Shawn.
Old 1st March 2007, 01:08 PM   #4
AMV8 is offline AMV8  United Kingdom
Hi
As the amplifier is a simple one why not hard wire the components together as shown in the schematic. That way you would not need a pcb.
If you do hardwire the components together do connect all the grounds of one channel to one point as mentioned in the notes and then connect that one point to the central ground point on the power supply.
Also as mentioned in the notes some of the components need to be connected to a heatsink.
Try building something.
Don
Old 1st March 2007, 11:58 PM   #5
TomWaits's Avatar
I forgot to mention the Mini Quasi .
Very easy build on this one, compact and easy parts to shop for. Contact the author of that thread, he is a wonderful person and he likes to help.
Good luck,
Shawn.
Help me design a pcb for redcircuits  10 watt amp..Hide this!Advertise here!
1000 Watt Sub Amp: Design / Build MJL21193 Solid State 327 1st July 2009 01:14 AM
First Watt F3 / Tube Audio Design TAD-125 Hibachi JFET amps vizion Tubes / Valves 1 31st August 2008 04:08 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 03:07 PM
60 watt design... rtill Solid State 11 10th January 2008 04:47 PM
My 50 Watt RMS design using Randy Slone's formulas corrieb Solid State 18 14th January 2007 01:22 AM
Copyright ©1999-2017 diyAudio
