Ciao!
I bought a used AVR3000 that loses its memory regarding the radio FM-band when the main power is switch off. Thats not all, when using the Tone in & Tone out I lose the right front channel.
Have anyone else had this problems??!!......................
If there is anyone who has the Service manual for AVR3000 I would like to recieve a copy if possible, thanks. //Flyier
Hugo,
thanks for the tip to reset the amp, it worked as a charm. I still have the problem with the memory (cap.). A pic will be comming soon, haven't got the time yet. BR // Flyier
PS. Does the AVR7000 and 3000 have the same solution and location of the memory back up with 4,7uF cap.?? In that case I've got the SM. DS.
Finaly, I've got the SM I think for the AVR3000 (as far as I
can see it's the same as AVR310). This helped me to locate
the cap and hopefully there will be enough space to replace
it easy.
Many thaks Hugo for the help and the tech spec for the cap.
I will be back to tell how it went to change the cap.
BR// Flyier
it easy.
BR// Flyier
Here comes some info about the cap change.
(sorry havent had the time before now)
There was some small problems to get to the cap but after chopping some stripes which held some cables it worked out Ok.
The cap to change is the black one which is in square shape.
- H-K AVR3000 loses memory among other things
