Old 16th November 2006, 12:57 PM   #1
bogdan_borko's Avatar
Default bjt/mos (class A) CFP
Hallo good people!
1. When designing class a bjt/mos CFP out stage does the bjt see Cgs or Cgd?
2. In aksa`s "Glass-Harmony" amp, he said that he used 2N5551 bjt with 1K collector load and that`s about 4-5mA bias current. Is that enough for driving IRFP9140 in CFP stage... ??
3.What is the most important to know when optimising bjt/mos CFP.
4. Does it need bjt base-collector cap and how to calculate the value?
cheers!
Old 16th November 2006, 03:10 PM   #2
ANyone knows?
I didn`t found "exact" data in previous threads...
Old 16th November 2006, 04:12 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by bogdan_borko
ANyone knows?
It is an interesting question.
How to make a Bipolar + HEXFET foldback device.
I am sure it would have some parameters with EXTRAORDINARY PERFORMANCE.
You don't see this often.
Because the HEXFET people don't use bipolar much
and
the Bipolar builders do not use HEXFET much, either.
Anyway,
this is a perfect issue for 'Professor' Pass to answer.
He would be the one to know ....
Maybe this topic would have better luck in Pass Labs forum
lineup
lineup
Old 16th November 2006, 04:39 PM   #4
thanks for reply lineup!
Cfp (bjt/mos) is more stable when operating in class a (that`s what I heard) and high local feedback of cfp is good for distortion minimizing, so I think that this combination could be bull`s eye...
This kind of CFP IMO is an opposite of IGBT.
< base - drain- source>
Old 16th November 2006, 05:05 PM   #5
Did it Himself
richie00boy's Avatar
Hugh (AKSA) recommends CFP in class-a because it has good distortion and because of class-a you avoid all the turn-off/on problems.
I have built a class-b amp with TIP29C/30C transistors driving IRF540/9540 devices, and it seemed to work well. I didn't test much with loads or waveshapes though.
I also had a lot of compensation caps all over the place due to an initial oscillation problem, and I never removed the 'excess' caps to see how it went without them.
You cannot calculate the cap values, you have to determine them with the actual board layout and real parts.
IMO 2N5551 and 1k is not man enough to drive MOSFETs, maybe Hugh has done some other trick?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 16th November 2006, 05:56 PM   #6
so Hugh...? Could you explain this if you have time...?
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Page generated in 0.13615 seconds (57.02% PHP - 42.98% MySQL) with 10 queries
