hey friends, i have two STK4050V, and i have this diagram, but , i need bridge this power amplifier, for get more power..how i can bridge this CI???????
#2 |
I guess, forget it... Datasheet says: "Recommended Operational Conditions, RL = 8ohm"
Bridged operation halfs the load seen by the amp. Bridging this chip is likely to overload it. THD, 0.08% 1W 1khz into 8ohm non inductive, are they kidding ? I would accept that without current mirror, not with... Mike |
#3 |
I once had a Panasonic stereo using a stk4131II which is a 20+20 watt version of this chip. I bridged it. It lived about 2 hours.
#4 |
as said, bridge would override currents output that is good for this IC recommended voltage supply is +-66 Volt for deliver something like 200 watt into 8 ohm even if some data is tested by using +-80 Volt and absolute max is +-95 Volt possibly you could parallel two STK4050V in some clever way and so get lots of power into 4 ohm but there are better options for get same output power in 4 ohm by other kits and projects
lineup |
#5 |
clear, do I like the idea of other projects, but do I have in my power these two integrated, but is the question, do you have some diagram to be able to Bridge these CI?..., I refer that I can get myself several of these CI, but I would like to know as the bridge, or that somebody becomes trained a diagram???
I would like to make bridge tests... |
#6 |
If you have 2 of them, build a stereo amp ?
Mike |
#7 |
It may be possible to bridge them in this manner and have them survive into 8 ohms only but no garentees. Requires 4 of them.
#8 |
no, I want to make a bridge, but that it is mono,i want mono phonic amplifier, not that it is stereo, the idea it is to add 200w + 200w in a single speaker...thanks
#9 |
jerluwoo:
but if I require 4 of these integrated, then which serious the complete connection of the CI, since each CI, it has 18 pins?????? |
#10 |
Hi,broka.You should get more chips and configure them in BPA.
| Full Bridge X Half Bridge: What's The Best? | CHACALPOWERS | Power Supplies | 8 | 18th July 2008 04:45 PM |
| Reopening an unfinished debate: Dual bridge vs. Single Bridge | xiphmont | Chip Amps | 15 | 26th February 2008 07:22 PM |
| The difference of Push-pull,Half-bridge,Full-bridge | digi01 | Chip Amps | 0 | 8th September 2006 02:10 AM |
| Whats the difference between full bridge and half-bridge SMPS ? | skaara | Class D | 6 | 3rd February 2005 07:23 PM |
| Page generated in 0.15504 seconds (57.62% PHP - 42.38% MySQL) with 11 queries |
