#11 |
On Hiatus
RIAA phono amps are in fact
BASS BOOST circuits If you skip the highest lowpass filter (2122 Hz), you get a bass boost filter that boost low frequencies. It will boost most below 50 Hz and get flat at about 500 Hz So you only have to modify a RIAA feedback filter in an OPamp. And select to wanted gain, of course. ------------------------------------------- ![]() Here is a Hifi RIAA pickup amp You only tweak the filter a little! /halo - the smartest boy alive |
#12 |
On Hiatus
Here you see an example of a Bass boost.
This is the feedback loop from OUTPUT to INVERTING(-IN) in an OPamp. The resistor from -IN to ground, that sets the gain is not shown. You select this resistor to suit your requirements. |
| Potentiometer with bass boost pin for Simple SE? | dubdub | Tubes / Valves | 4 | 27th October 2008 03:57 AM |
| Bass Boost Circuit | metal | Chip Amps | 0 | 15th November 2005 08:29 PM |
| bass boost | odysseybmx414 | Chip Amps | 3 | 26th August 2005 09:05 AM |
| Bass Boost Q | UNDERSTANDIN | Subwoofers | 5 | 26th July 2005 08:49 PM |
| shivas sub& bass boost circuit | busterno1 | Subwoofers | 7 | 1st September 2004 08:02 AM |
