Need small coupling capacitors
Old 12th November 2006, 08:34 PM   #1
pandaemonium9 is offline pandaemonium9  Canada
Default Need small coupling capacitors
I would like to replace the electrolytic coupling capacitors in my pre-amp and DSP but I have too little room on the boards for big poly caps. Anyone know of any small decent caps I could use? They currently use 4.7uF@50v between NE5532s (changed from 4558s). Would it be useful to use small value, high-grade bypass caps across the electrolytics?
Old 12th November 2006, 10:07 PM   #2
sharpi31 is offline sharpi31  United Kingdom
Black Gate N 4.7uF 50V are great for signal coupling and PSU duties, and not too expensive....
Old 13th November 2006, 12:37 AM   #3
Minion is offline Minion  Canada
You can also use good quality Metal Film or Mylar Caps which are Much smaller than Poly caps but offer simular performance and can be found for a fraction the price of Poly caps....
I recently picked up 100 0.1uF Metal Film caps for about $3.....
Cheers
Old 13th November 2006, 06:00 AM   #4
RogerGustavsson is offline RogerGustavsson  Sweden
Look for Wima MKS2 or Evox Rifa MMK. Both uses metallized polyester film (mylar). 4.7 F/50V are 7.2x7.2x13 mm. Pitch is 5 mm. Wima can supply 6.8 and 10 F too but with a lower voltage rating.
Old 13th November 2006, 07:51 PM   #5
is the pre a valve (tube) type or opamps?
If opamps then you don't need 50V cap rating.
A metallised plastic film is better than any exotic electrolytic. But they are usually bigger.
Search the catalogues to find something that fits.
BTW 4.7uF in that 7mm package is very small. You will struggle to find anything smaller.
regards Andrew T.
Need small coupling capacitorsHide this!Advertise here!
Electrolytic coupling capacitors ? heater Chip Amps 20 12th December 2010 12:24 AM
Polarized capacitors for coupling NIC1138 Parts 7 1st June 2007 09:37 PM
AC coupling capacitors... Frazzled Solid State 8 30th June 2004 07:28 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 02:29 AM
Copyright ©1999-2017 diyAudio
