I have an Entech 203.2 DAC that uses an OPA2134PA for its output.(this isn't a question about anything digital)
This DAC has no DC on its output until a low frequency signal is passed through it. Starting at around 40hz or so some 20-40mv of offset starts to show up. I have the DAC DC coupled to my amp and at lower frequencies and high enough volume my amp will go into protection. I have little experience with opamps or even electronics in general, so I need some help trying to figure out what would cause this. ![]() Thanks. |
#2 |
it is not a power amp problem. It does not appear to be an opamp problem. That only leaves a digital problem. I assume you do not want to fit DC blocking caps around the opamp and before the power amp. If you avoid the LF content, does the DC output offset stay stable and low?
regards Andrew T. |
#3 |
Hi Andrew, thanks for the response.
I would like to avoid DC blocking caps as I am really enjoying the sound without them. With any other frequency above 40-50hz the measured DC is very low, around 1mV. I've tried two different digital sources going through the DAC and they both produce the same results. |
| Rotel RCD-971: Anyone revised the PCM63 Current Output Config-Source of DC Offset??? | dtm1962 | Digital Source | 3 | 25th November 2010 09:39 PM |
| cmoy with 1uF input cap, DC offset from source still getting through | morfic | Solid State | 11 | 5th August 2009 02:41 PM |
| DC offset question | Nicks | Chip Amps | 27 | 29th December 2005 07:42 PM |
| 36 V DC offset when source connected | revell | Chip Amps | 12 | 27th February 2005 08:29 PM |
| Help - DC offset question | mikebarney | Chip Amps | 4 | 2nd April 2004 11:20 PM |
| Page generated in 0.06861 seconds (68.57% PHP - 31.43% MySQL) with 10 queries |
