Proposal of new test signal for amplifiers, with regard to HF interference
Old 12th November 2006, 07:43 AM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default Proposal of new test signal for amplifiers, with regard to HF interference
My proposal and first results are here, looking forward your comments:
http://web.telecom.cz/macura/mixtest.html
Pavel Macura
Old 12th November 2006, 12:40 PM   #2
PMA's Avatar
Any opinion?
Old 12th November 2006, 01:18 PM   #3
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Sine mixed with square?
Such signals were used to measure TIM in 70's.
If your square is steep enough, you can actually observe slew limitation at output of some circuits. I think that 30kHz square should be at least 100 times lower in amplitude then.
regards
Adam
Old 12th November 2006, 01:23 PM   #4
PMA's Avatar
Adam,
I know DIM30 and DIM100 signals. They consist of 3.18kHz square and 15kHz sine. Square amplitude is 4:1 to sine.
May goal is very different. To simulate HF content at player output. 30 kHz corresponds to switching frequency of DC-DC converter. Square simulates harmonic content of fast impulses with 30 kHz repetition. Small square amplitude corresponds to interference amplitude related to useful signal.
Pavel
Old 12th November 2006, 02:06 PM   #5
darkfenriz's Avatar
Still, I'd prefer triangle.
First it is more similar to SMPS voltage ripple, second there is no fear of slew overload a circuit with a triangle. One the other hand it has -12dB/oct spectrum vs. -6dB/oct for square.
Just my suggestion.
regards
Adam
Old 12th November 2006, 03:02 PM   #6
PMA's Avatar
Adam,
I do not think so. The HF impulse residuals at CD player output have rise time of 10ns. Just a derivative of square. Triangle is integral of square and thus very easy signal for amplifier.
I am not afraid of the slew rate limitation. Square amplitude in my test is 30dB under sine amplitude.
For me, amplifier must whithstand square wave test, 10kHz at 50% power for one hour into load. If not, the amplifier is not worth any consideration for me.
Pavel
Old 12th November 2006, 04:11 PM   #7
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, PMA,
Good one
Since the disturbance is unadvoidable in home audio environment these days, could this thread gives solution how to advoid those HF intermodulation with music signal?
BTW, this is about square wave and audio signal (sinusoidal signals)
http://www.diyaudio.com/forums/showt...689#post806689
Old 12th November 2006, 04:24 PM   #8
PMA's Avatar
Originally posted by lumanauw
Hi, PMA,
Good one
David,
this is what I have been permanently trying to work on. Recommendations would cover construction, wiring, input filters. Unfortunately, audio is only my hobby and my time for it is limited. On the other hand, I design instruments for operation in harsh EMI invironment as my professional job. I will try to give some recommendations, after I have time to translate them from my similar document in Czech language.
Pavel
Old 12th November 2006, 04:28 PM   #9
PMA's Avatar
Right now, my colleague Vladimir has made a similar test on commercial SONY amplifier. Test signals were 6kHz sine + 31kHz square, amplitude ratio same as in my measurements. 16W into 4ohm load. Please compare with my Symasym measurement in post no. 1 of this thread.
Old 12th November 2006, 04:31 PM   #10
PMA's Avatar
This is Symasym for 1kHz sine + 34kHz square:
Proposal of new test signal for amplifiers, with regard to HF interferenceHide this!Advertise here!
Small-signal modeling of self-oscillating amplifiers sovadk Class D 28 4th May 2014 02:15 PM
Intermodulation test signal BitPoint Digital Line Level 5 6th April 2009 11:06 AM
Jitter test signal - 11025+229.6875hz. How to ? percy Digital Source 5 25th April 2007 12:13 AM
What's a good test signal to match two decks' azimuth with? damianm Analogue Source 4 18th June 2006 02:00 PM
Best Digital (bit perfect) Test Signal? drewm1980 Digital Source 3 23rd May 2005 12:09 AM
Copyright ©1999-2017 diyAudio
