Amplifier Input CSS, good thermal data + Red LED model
Old 12th November 2006, 02:01 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Smile Amplifier Input CSS, good thermal data + Red LED model
hello
CCS in Amplifier with low thermal drift + Red LED spice model
Red LED is very good and useful for CSS, constant current sources, in amps.
If, for example, placing a Flat Red LED into close thermal contact with a TO92 Transistor
you get almost perfect thermal compensation.
And the CSS keep the current very constant.
For an Amplifier input differential stage this is a very good thing.
Especially when we need low offset and best performance at high/medium voltage gains.
Because if CCS will deviate, then also offset will change.
RED LED also makes a low noise voltage reference in these CCS,
if used with a Diode Current of like 2 - 5 mA.
See my attachment drawing
for one such very good constant current source.
My problem is that in my Simulation Software, I have no good spice model.
The RED LED that comes with Electronics Workbench Multisim,
has only one voltage 1.66V, whatever current I put into the LED.
This is bad! You would expect better from an advanced commercial spice software.
I want to have a good model for a normal standard RED LED. (there are many types)
Those you can buy 100 pieces of, for a low price.
lineup
lineup
Old 12th November 2006, 11:29 AM   #2
Gold_xyz is offline Gold_xyz  Italy
Gold_xyz's Avatar
You can try to ask at vishay http://www.vishay.com/leds/
for best spice model
also look this document... http://72.14.221.104/search?q=cache:...&ct=clnk&cd=10
(cache copy because this site is unavailable)
bye
My English originates from here
Old 12th November 2006, 12:35 PM   #3
lineup's Avatar
also look this document... http://72.14.221.104/search?q=cache:...clnk&cd=10</a>
bye
Thanks,
Gold_xyz
I go have a look.
lineup
Old 12th November 2006, 01:03 PM   #4
Gold_xyz's Avatar
Hi lineup
I have also found other links...
http://www.orcad.com/documents/commu...pice/tn27.aspx
http://www.cadence.com/appnotes/Mode...aserDiodes.zip
http://www.edn.com/article/CA60961.html
Bye
Amplifier Input CSS, good thermal data + Red LED modelHide this!Advertise here!
Biasing/thermal compensation of Thermal Trak transistors Bob Cordell Solid State 161 8th March 2014 09:42 AM
Is the PCM-61 Dac are I2S or EIAJ data input ? gaetan8888 Digital Source 2 7th August 2007 06:08 PM
Elegant way to feed parallel data-input DAC chips ? Bernhard Digital Source 27 18th April 2005 10:28 PM
External reclocking and error due unequal input data and clk freq. andy2 Digital Source 8 3rd April 2005 03:51 PM
Copyright ©1999-2017 diyAudio
