Pcb 300 W
Pcb 300 W
Old 13th November 2006, 08:04 PM   #21
fjromero is offline fjromero  Spain
to see if this scheme is the correct one, warm greetings.
Old 13th November 2006, 08:17 PM   #22
K-amps is offline K-amps  United States
K-amps's Avatar
If you are open to changing the OP devices, why would you not use the much better MJ21195/96? Stability?
Old 13th November 2006, 08:21 PM   #23
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Three pairs of output devices are still not enough to safely handle 280/350W at a 45 degree phase angle
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 13th November 2006, 08:28 PM   #24
K-amps's Avatar
Took another look... its an old design (maybe later) with 20 year old parts... TL071???
Lowering the rails to +/-70 should do it... or add another pair.
I have used a similar design with +/-68vdc. 4 pairs of 15003/4 and they ran four jbl 2225's all day. i.e. 2 ohm loads.
Old 13th November 2006, 08:30 PM   #25
edl is offline edl  Hungary
edl's Avatar
PL400-II (almost the same schematic) used 3 pairs of MJ15024 at 80V rails!
Old 13th November 2006, 08:38 PM   #26
Jan Dupont's Avatar
The Phase Linear 400-II are notorius known for their weak output circuit.......
I have personally repaired/replaced output devices on app. 20 different PL400's over the year, even though the PL400 never was very popular in little Denmark and I have never worked at an official PL workshop
Old 13th November 2006, 08:53 PM   #27
K-amps's Avatar
Not having touched one before, was the heatsinking adequate? Didnt Bob carver use a 125v mains cap with 130v supply in one design?
Old 13th November 2006, 09:00 PM   #28
Jan Dupont's Avatar
Heatsinking was ok I think ...
However I never actually measure the temperature
Bob Carver did made some strange choices in his desig, however so did many others....
Remember the Onkyo M504 ?? Output caps did go all the time, even though it was a good amp
Just because it was a commercial amp, doesn't make the circuit right.... That's why we make DIY
Old 13th November 2006, 09:32 PM   #29
That it seems to you this other scheme.
greetings
Old 14th November 2006, 01:21 AM   #30
K-amps's Avatar
Personally I like this one better.... non-reactive 2 ohm load is possible with this depending on supply droop. Though I still prefer the MJ21193/4/5/6 because of better gain.. either that or you get more robust drivers.... Though I have always liked the 669/649's...
Pcb 300 WHide this!Advertise here!
