hi there, this is my first ever post !!!
I got the amp second hand, so I dont know its history..... When connected up, it powers okay, but when you play a CD/record the sound is distorted...... when i looked inside, 2 of the interal glass fuses were blown....I replaced them and it was okay for a short while, but its happened again...... does anyone know what might be causing this, whether there might be a chance i could fix it myself......(I dont play the amp loud)..... thanks alot.... |
#2 |
Magneto the Gravity Man
The distortion is obviously because the fuses are blown. The amp is not operating with the correct voltages when the fuses are blown.
Replacing the fuses gives correct operation until they blow again. So, what is causing the fuses to blow.?? With the volume down and no input, !. do they still blow ?? 2. Look inside for signs of overheating near the output transistors.[burnt components or circuit board]. 3. Does 1 or more of the output transistors get hot / hotter than the others ?? What model is the NAD ?? Andy |
#4 |
Thanks GOLD XYZ & POYTON...
the amp is a NAD 3020e I cant see F1 or F2, they look like P503 & P505.... I cant see any burnt components...... I will have to get some more fuses before I can test it again !!!! andy, what would the output transisters look like ?? are they green & battery shaped ?? thanks again |
#5 |
The output transistors are easy to recognise. The are sitting in the middle of the case, on a L-shaped aluminium.
4 shiny metal cases with "wings". |
#6 |
a schematics of nad3020 is posted on eserviceInfo
http://www.eserviceinfo.com/download.../NAD_3020.html PSU : http://www.tcaas.btinternet.co.uk/nad3020ps.gif on schematics i see 4 fuses on supply. Fuse 1 and Fuse 2 = 1 Amp Fuse 3 and Fuse 4 = 3 Amp |
#7 |
GOLD XYZ....hello.....................
i think it is Fuse 3 & 4.....(F501, F502)...but they are on the board it says T4A /250 V...... Not 3A ?? I think it is different because my amp is NAD3020e....... (e)... |
#8 |
Hi Linton
I have seen for schematics of NAD3020E but I have not found anything perhaps the "E" version is it differs only for some particular but probably the schematics is almost equal. The fuses surely supply the end stage and I think that the end stage transistors should be verified. On the original schematics (of 3020) the end stage transistors are the 2N3055 & 2N2955 Check these transistor before replace fuses Attention that the capacitor remain charged also when the amplifier is disconnected from electricity
#10 |
Thanks for all your help....
Your english is okay/good..... I dont have any technical knowledge !! Do you know How I can I check the transistors ?? (in my amp, there are 2 x 2N3055 T8651 & 2 x MJ2955 T8706) what does a capacitor look like ?? thanks for all your help/time....... do you work in electronics ?? |
| A couple questions about blown output fuses, and protection (Rotel RT-990BX) | terasearch | Solid State | 3 | 2nd August 2009 11:50 AM |
| Help with blown Fuses LM3886, Chipamp.com | schmalex | Chip Amps | 21 | 23rd November 2006 02:23 PM |
| sound distorted from Jolida JD100H | maya1 | Digital Source | 0 | 11th June 2004 10:34 AM |
| Buzz, then blown fuses | DrStrangelove | Tubes / Valves | 20 | 18th May 2003 09:49 PM |
| Page generated in 0.11236 seconds (78.50% PHP - 21.50% MySQL) with 11 queries |
