In Active crossover application, OPA2134 and OPA2604, which is better?
Old 9th November 2006, 10:37 AM   #11
lt cdr data is offline lt cdr data  Wales
tl072 and lf353 are the industry std. ones using in some very good actives
Old 9th November 2006, 10:44 AM   #12
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Yeah and NE5532's are the industrie standard for output opamps and we all know they sound like ----, so do the TL072's and the LF353's.. It's because they can buy them in bulk for a couple of cents and they do the job, but only just.
My two cents worth
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 9th November 2006, 08:32 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally posted by mlloyd1
i think the opa2604 is (at least designed to be) unity gain stable - no minimum gain requirement, such as the OPA637 has.
i think Nelson was pointing to something else in the design/operation of OPA2604?
The circuit didn't oscillate - it sounded bad.
This is a topic worthy of a thread all by itself, as it applies to
the sound of op amps, chip amps, and other circuits with
high open loop gains.
It is my observation that as the phase margin gets thin, the
sound starts to suffer, and while many of these circuits don't
show actual oscillation, the approach to that boundary puts
the behaviour into fractal territory.
It's easy to experiment with, as pointed out in the first post
of my thread "7 easy pieces"
The example schematic was:
www.passlabs.com/np/GC-VAR-INV-FDBK-1a.pdf
In Active crossover application, OPA2134 and OPA2604, which is better?Hide this!Advertise here!
Ad847,ad797,opa2604,OPA2132,OPA2134 : Sop8 To Dip8 uhcmos Swap Meet 1 3rd December 2008 12:28 PM
DIY active x-over for 2.1 application peter_m Multi-Way 17 16th December 2007 05:22 PM
Is a crossover circuit really needed for this sound reinforcement application tspringer99 Multi-Way 17 24th January 2006 04:35 AM
OPA2134 or OPA2604 JoeBob Solid State 5 7th January 2002 12:20 PM
Copyright ©1999-2017 diyAudio
