#41 |
Normally there r two type car subwoofers available. one to be used in box & another for open air. The .QTS & Vas is very much different for both types. The SPL level of free air type is high & for cabinet type it is low. Just check what type of subwoofer u r using?
#42 | |
When I said they don't know anything about speakers; I mostly meant their general construction. They made the surround so tight I was surprised it lasted as long as it did. I'm sure you can find the episode on the net. Watch it and you will see what I mean. |
#43 |
On the topic of speakers causing structural damage to houses or cars, I will mention that I notice structural degradation of my house most likely caused by the operation of my stereo.
It is evident that there's a lot of vibration going on since small plants on end tables and dishes in the cupboards are visibly vibrating and shifting. The only things I really notice going on with the house's structure are apparent softening of certain things like the floorboards, door fittings, windows, etc. It is rather interesting. There are a few acute artifacts though; one being that at high enough SPL and on certain frequencies, the power meter attached to the outside wall vibrates enough that the disc jams against the front flange. It doesn't stay jammed, just rubs while it's vibrating. Obviously too loud.
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#44 |
When I made my isobaric subwoofer http://www.diyaudio.com/forums/showt...52#post1049952
I had to damp a lot of things in my house that were rattling. Mamory foam topper is the source of damping material.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#45 |
Yeah, the same applies at my place. We have to 'adjust' certain things so that they don't fall over. Paintings falling off the wall has been a problem. Books falling out of shelves is another.
A friend had similar funny ocurrance with his stereo; he had it set up at his father's place and during our listening session, an entire selection of curios worked their way into a terrified bunch at the back of the china cabinet. A wine bottle worked its way out of the wine rack and blew up on the bedroom carpet. Needless to say, there was proof of what had happened when his father got home.
| Is it normal to think this way? | gain-wire | Instruments and Amps | 3 | 16th October 2008 11:09 PM |
| WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) | gtforme00 | Swap Meet | 9 | 3rd June 2008 09:57 PM |
| Is this normal? | A_Reef_Scene | Multi-Way | 2 | 7th March 2007 06:51 PM |
| Shorted power supply destroys amplifier | jpattison | Chip Amps | 12 | 14th February 2004 12:48 AM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
