Old 5th November 2006, 01:13 AM   #1
broka is offline broka  Chile
Default Amplifier For 400 W_rms
hey friends. i need make a power amplifier
but for 400 watts in RMS
somebody have a good schematic and pcb design???
i need cuality of circuits. I want to make a good work.I have two speakers, each one of 400 rms of 8 ohms
, the other time it manufactures an amplifier of 200 rms and I burned
if somebody has a design of the PCB and a good outline that please the post, greetings to all thank you
Old 5th November 2006, 03:05 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Amplifier For 400 W_rms
Somebody have a good schematic and pcb design???
I need quality of circuits.
You could check out Anthony Holton amplifiers.
He makes good amps that are high quality and tested to work alright.
This is why he dare to offer them for public sale.
Without risk of customers and diyaudio people will complain, too much ...
And he knows well how to design for higher powers!
He tells, he has been doing this since 1994, for 12 years.
Most of his amplifiers can be delivered as KITS .... or fully assembled.
MOSFET AV400 Power Module =PICTURE
Specifications:
400 Watts RMS into 4 Ohms
220 Watts RMS into 8 Ohms
Frequency Response: 10hz to 110khz
Noise -126db
THD 0.05% @ Full Power 4 Ohms
MOSFET AV800 Power Module
Specifications
820 Watts RMS into 4 Ohms
450 Watts RMS into 8 Ohms
SNR: -122dB, Distortion 0.01% 1khz
Power Supply Requirements
Mono block applications
1 x 1.2KVA Toroidal Transformer
with 2 x 65vac windings (loaded rating)
Filtering min of 10,000uf per voltage rail
1 x Bridge Rectifier MDA3504
Antony is a member of diyaudio
under alias The Saint
and his contact data is:
Anthony Holton
http://www.aussieamplifiers.com/
EMAIL: aussieamps(at)netspace.net.au
Go for quality and some approved design, in the first place.
It will probably save you from troubles from less tested schematics
and some good money, too,
if you need to try something real after investing in several questionable projects first.
lineup advice
lineup
Old 5th November 2006, 02:44 PM   #3
or, very good information, excellent, the problem is that I am from santiago - chile, then I have problems with the expenses and costs of shippings. however with a good design in PCB and outline can build the AV800 that is the one that need, greetings friend...
Old 5th November 2006, 03:13 PM   #4
looks I have these planes that it is the AV400 according to me, but according to the characteristics that you tell me for a load of 8ohms, I need an AV800, if you can get yourself the planes, serious of a lot of help, I happen to you those of the AV400 that are in the enclosed file, greetings friend
you can download a file in this link:
http://www.megaupload.com/?d=CRNJ3WSF
Old 5th November 2006, 04:21 PM   #5
lineup's Avatar
I downloaded
Protel MOSFET 400 Watt.
It has +70 volt and -70 volt.
Using 4 x IRFP240 + 4 x IRFP9240 MOSFET in Output.
It is same power like Aussieamplifier AV400.
Will be something like 200-225 Watt in 8 Ohm, max. ( If +-60 Volt Peak Output )
And 400 Watt something, in 4 Ohm.
It is a very good schematic!
Good amplifier.
You should contact Anthony Holton.
Maybe he will help you ....
You have his email .. see my first post here.
Here is his profile:
http://www.diyaudio.com/forums/membe...fo&userid=2681
And here is his website:
lineup
lineup
Old 5th November 2006, 07:19 PM   #6
Gold_xyz's Avatar
I have also the new NX400 seen
with a very low distorsion....
http://www.aussieamplifiers.com/index3.htm
bye.
My English originates from here
Old 6th November 2006, 03:17 AM   #7
LINEUP:
then the diagrams that I Uploaded, are of the amplifier AV400??????
Old 6th November 2006, 07:58 AM   #8
edl is offline edl  Hungary
edl's Avatar
LINEUP:
Yes, that is!
Old 6th November 2006, 11:55 PM   #9
thanks for your answer, however , i have the av400 pcb design and schematic,
but i am interestin for the AV800 PCB protel diagram, and schematic...
Old 7th November 2006, 12:41 AM   #10
sam9 is offline sam9  United States
sam9's Avatar
You may still be able to buy Opti_MOS PCBs here.
http://www.diyamp.net/
or here
http://www.ledeaudio.com/audio_kits.html
Exstroyer x Amplifier...Ex amp...my amplifier MJL21193 Solid State 131 28th July 2009 01:26 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.12443 seconds (79.91% PHP - 20.09% MySQL) with 10 queries
