I have a 5 year old Newcastle R-956 integrated amp that recently developed a smoking problem. The other night, I turned the amp on, heard a crackling noise and saw a little smoke coming from the amp. I removed the cover (after unplugging of course) and was able to take a pic of the location of the short/arcing. It doesn't look like there was too much damage, but I am not sure of the cause or how to fix (I am waiting to hear from the manufacturer to see if they will fix it first)- I am mainly concerned about it happening again and causing a fire. Any advice is appreciated.
Thanks, Jim |
#2 |
Looks like a couple output devices are toast
![]() Have any idea what the part numbers are ?
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
I can't see the part number- it's under the board and the only way I can see to get to them is by de-soldering all of the connections.
Any idea what would cause the short/arcing? |
#4 |
I'm guessing they will be Sanken SAP15 devices. With discolouration like that, they will be toast and need to be replaced.
Newcastle would be a brand name of Sherwood ![]() The quality of construction looks awful! That PCB material is like the cheap crap that I buy from Maplin because it's cheap |
#5 |
Reason for catastrophic failure:
1. Overdriven into sustained clipping/distortion. 2. Shorted output cables. 3.thermal fatigue. P-N junction just chose to "checkout"
#6 |
How can I get to the screw heads to replace the transistors (they are under the board with ~1 inch of clearance)? Sorry if this is a stupid question - I don't have any previous experience doing these kind of repairs, just building an occassion computer and other basic DIY projects.
#7 |
Hi JimLish,
Desolder the leads and lift the board off. It's actually very easy to do. -Chris |
| OZ DIY :: Sydney/Newcastle ?? | Andy G | Multi-Way | 24 | 1st April 2012 10:28 AM |
| Sherwood Newcastle | hatchiruko | Everything Else | 0 | 21st December 2004 01:56 PM |
| FS: Sherwood Newcastle R-725's 165 RMS/ch | tunemanjjw | Swap Meet | 1 | 20th July 2004 07:16 PM |
| Like New Sherwood Newcastle R-626 | corryn00 | Swap Meet | 0 | 11th June 2004 04:14 AM |
| Page generated in 0.08466 seconds (76.43% PHP - 23.57% MySQL) with 11 queries |
