I asked this question before but nobody was able to answer it straight and 100%.Let me try again: I have 30 pieces of ST 60N10 MOSFET (200 W).Here is a data sheet (please read-pdf): http://www.st.com/stonline/books/pdf/docs/3105.pdf Can we use this MOSFET to build PA Amplifier? What schematic should I use to build one(post it please)? How much power should we expect from one pair of these 200W MOSFETS on +/-42V and 4 ohms? Thanks everybody for help. Best Regards |
#2 |
Any Ideas???
#3 |
with +/- 42Vcc supply on 4 Ohms you can obtain around 200W
For complementary output you need also P-type channel MOSFET. Some schematics to be found at this very good site http://sound.westhost.com/projects-1.htm... to see also the schematics on this thread [DIY] HEXFET AMP total disaster? Bye |
#4 |
I would like to use just N-channel MOSFET's in quasi design.
Did you check data sheet?You think that this MOSFET would provide nice sounding amp? So.one pair would be able to handle 200 W of power on +/-42V? Thanks |
#5 | ||
hi
they could be used, if using proper drivers or VAS stage working at a bit higher current. Because of the very high input capacitance these beast are not as easy to drive. Normal for IRFxxx is like 1000 and max ~2000pF Ciss. And lateral MOSFETs like 2SK1058 can have as good low Ciss value as 600pF This makes these very easy to drive and sometimes a VAS stage only at 10-20 mA can drive them directly. But, again in the correct supporting amplifier circuit they would work, especially when need to put out LARGE CURRENTS = low impedance speakers and high powers. However, you cant use them with higher voltage suppy than 2 x 50 Volt. This would limit max output power a lot into 8 Ohm. Such an amplifier would be more suitable for 2-4 Ohm speakers. Or if paralleling 4//4 Ohm (Sub-)Woofers. When they would be able to give Large Currents to load. lineup
lineup |
#6 |
Can you guys post schematic that would have VAS implemented to drive these monsters?
Thanks |
#7 |
IRF540 : Id max 28A, Vdss 100V, Pt 150W RDS 0.07
STH60N10 : Id max 60A, Vdss 100V Pt 200W RDS 0.025 you can replace with your STH60N10 the IRF540 on the schematics placed in this therad [DIY] HEXFET AMP total disaster? however it can adjust some value for supply at 42Vcc bye |
#8 |
Would "Citation" amplifier be right choice to use these?
Citation schematic: http://www.passdiy.com/pdf/citation.pdf |
#10 |
Or maybe tis schematic.IS this will be OK to run these transistors:
| More op-amp/mosfet power amplifier | Dusk | Instruments and Amps | 7 | 14th April 2007 06:42 AM |
| power amplifier mosfet | j.p-ni- | Solid State | 6 | 1st October 2004 06:47 PM |
| 1KW Power MOSFET Amplifier | hostname | Solid State | 1 | 3rd August 2004 01:00 PM |
| Page generated in 0.10720 seconds (79.67% PHP - 20.33% MySQL) with 11 queries |
