Hello, I started building a amplifier some time ago. I wanted a simple design what would works stable and will perform very good. I decided to go with a working design from a electronics book.
After some reading and searching I found "Giesberts HEXFET AMP" the best to go with. I trusted blindly that the design will perform like described so I made 12(!!) PCB's right away. Now that they all where build up. I was going to test a module so I toke some crocodile wires and connected the module up to my labpower supply and turned it on. I draw the maximum current to 0,5 amps and the voltage to 10 Volts. The led from current limitting directly started lighting?? Thats weird. Turned the power off and checked and rechecked all the components en connections. Every thing was just fine. So I typed "Giesberts HEXFET AMP" into google and guess what !? I got lots of hits with the same problem. The weird thing is that some blame that it does work; and other say it needs modification(s), then some one says that I need to place 100N in parallel with R30 & R31 to prevent it from oscillating. Because the resistors will work like a coil. I did this but no difference. The amp runs fine on symmetric 5V but if I put it higher the current rises explosively and the fets run red hot . I also removed the fuses from the sockets and put on the power, @ about 15Vs the resistors R22 & R23 starts smoking. Thats also strains, no speaker connected, mosfets disconnected from the power supply and still things start smoking. PLEASE HELP ? I don't know where to start, I have a oscilloscope and dual labpowersupply.I found a thread in this form and carefully read it, I tryed to increase R26&R29 but also no difference! Here is the link to the thread : Click About assembly: I did not pair the transistors bc550 and bc560 could this infect the stability? (I did thermally pair them with a piece of copper but did no pair the characteristics) Here is the schematic: ![]() Sorry for my bad English. |
#2 |
If R22 and R23 are smoking then the transistors are either oscillating or conducting full. See what voltage you get at the base of each one and try hooking the scope up also. Not sure what else could be causing it, maybe an error with the PCB or bad layout.
#3 |
I built 6 of these almost 10 years ago and cannot recall any serious problems, except for it being pretty sensitive to hum (low PSRR). Also, they seemed to have a rather harsh top end. They cost pretty much nothing and were quite reliable (I think the're still running!) I didn't do any matching of anything, neither did I try and thermally couple them. In other words, I didn't do anything fancy or special at all.
I'm thinking there must be something wrong with your bias circuit around T7. When you connect your scope to the output, does it latch to a rail or does it stay at 0V? Cheers Gert
The walls between art and engineering exist only in our minds - Theo Jansen |
#4 | |
It verifies that the BD140/141 have not burnt.. try you to disconnect the base of these. later check the base signal from T1 and T3. There is perhaps some problem on the differential amplifiers. bye |
#6 |
I remember this IRF540 / 9540 HEXFET from Elektor magazine.
The output drivers T10 T11 and output transistors T12 T13 has a voltage gain of 2-3. Gain ~= (150+68)/68 There is a local feedback in this stage using R31 R30 to set this gain. The problem is you have no capacitance to compensate and so make this local feedback amplifier stage STABLE. These HEXFET like most MOSFET are very fast, compared to normal BJT Power transistors. The usual way, as you mention, to put a cap in parallel with R31 may not work as well in this type of Current, Emitter, Feedback configuration. The same problem can sometimes happen in Complementary Fold-Back darlington configuration. In this case we can say we have two CFB in push pull. With some resistors to reduce gain. When emitter feedback is used ( R31 is providing feedback current to EMITTERS of BD139 BD140 ) you will have to try to break this oscillation loop using the slow down fiter capacitors in some other place. ------------------ What we have to play with is the loop ( I only speak of the upper part now): R31 - R25 - T10 - R26 - T12 - R31 See my attached part of schematic. Somewhere where is best place, we have to put a compensation, slow down, capacitance. See alternative A. in my drawing. The usual way is to put a cap across R24. Cap Cx. I would try a cap with value: 1nF ... 22nF Of course you would put same value cap in the lower half of amplifier .. cap across R27 The procedure is the following. 1. Begin with the higher value caps, 22nF 2. If amplifier is stable, take the nest lower 50% value = 10nF 3. If still stable take next = 4.7nF Repeat this until amplfier is no longer stable. Say it starts oscillate again at 2.2nF. And is stable at 4.7nF. Then I would, to have a safety margin, use 6.8nF for these compensation caps. Don't forget to add same value cap across BOTH R24 and R27. --------------- The optimal way to compensate is to use alternative B. in my drawing. Ry can be maybe 2.2 Ohm - 22 Ohm and the cap Cy same as in alternative A. .. 1nF - 22nF To determine the optimal values we would use oscilloscope and adjust for best possible looking squarewave. If I am sure this will work for your amplifier project? The truth is ----- I AM NOT SURE. I have to put in a disclaimer, isn't this what they call it. But the method I describe is the way I have seen used in other same type of amplifier stages. lineup
lineup |
#7 |
in my experience, mosfet power amps oscillate at low voltages. I think it´s caused by increased capacitance of fets at low voltages, resulting in alterations in the frequency compensation.
#8 |
Try 22ohm for R32 and R33.
That works!!! |
#9 |
#10 |
Okey, I found the problem, I pulled the fuses. Resistor R22 and R23 runs hot. the only thing that can cause this is:
-T8,T9 or T7 defect -T3,T1 defect, or wrong type. -T6 or T5 defect or wrong type. Then I found out that T6 and T5 runs a little warm, that is strange because it only needs to produce a steady 3ma current. Then I found out the most stupid mistake! I putted the leds in wrong polarization! After I turned them around, the circuits runs alive. putted the fuses to there place, but the current again raised like hell, on 7,5V symmetric it runs a 200ma. Putted the scoop to T10 collector and saw a huge oscillation there. Putted caps in parallel with R30 & R31 guess, it works! putting the caps resolves all the problems with this circuit. It runs just great now, I let you guys know if al the other 14 will work to.
| Ebay Tube amp buy disaster | itsmejto | Tubes / Valves | 55 | 20th June 2008 08:34 AM |
| Disaster NEED HELP PLS! | leander | Solid State | 11 | 19th September 2005 06:59 PM |
| Near Disaster! | Bikeman | Everything Else | 1 | 4th September 2003 05:18 AM |
| 3rd generiation HEXFET vs. 5th generation HEXFET | DarkOne | Solid State | 3 | 12th April 2002 07:51 PM |
| Page generated in 0.13145 seconds (86.50% PHP - 13.50% MySQL) with 11 queries |
