I expect to build a power amp and unfortunatly the power tranfo is quite small so to protect the transformer I will use a slow turn on device.
I would like to use a relay in the bleeder circuit. Relay has a nominal voltage of 24 volts and pick-up at 10 volts ( 42% of nominal voltage ) with 3 K resistor will pick-up around 24 volts and nominal voltage will be set OK. A TRIAC in primary of transfo will short current limiting resistor. Did anybody try a similar circuit? Should I go ahead ? |
#2 |
Did it Himself
Firstly, you have misunderstood what soft-start is. It's not going to protect your transformer for being too small, in fact if your transformer is small (300VA or less) then you don't even need it. What it does is prevent your lights dimming and wear on your power switch and a 'thunk' sound at power on.
Now on to the circuit. The triac is pointless, you might as well short the resistor with the relay. I personally don't like the relay drive on the secondary like you have, it's prone to causing a flaming the primary resistor if the secondary voltage doesn't quite get up to full voltage. Better to drive it all off the mains, it doesn't take a complicated circuit.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
The slow turn on is very suitable for toroidal transfo
and with a large capacitor supply. in many application this device is used. Professional amplifier, microwave owen, etc. etc. I have seen this schematisc above all without triac, but with a little cap for eliminate the switch on transient. |
#4 |
Slow turn on will reduce stress on all componets: main, switch,fuse, transfo & rectifier.
I will use a lot of capacitor to set time constant of power supply below time constant of feedback & input filter, but this lot of capacitor is very demanding on transfo & rectifier, this is why I expect to use slow turn on. I woul like to usea small relay to keep bleeder current to a minimum value. Using a relay is simple and will control time constant of sytem but a low power relay with small switching capacity cannot switch full power of transfo, this is why I use a TRIAC. My question are will the triac need a snubber ? since there is a low value resitor across Will the TRIAC switch close to zero enough ? or will I get a lot of harmonics in tranformer voltage ? |
#6 |
What about this?
| Slow Turn On Led | hernanstafe | Parts | 5 | 1st May 2007 11:13 PM |
| Full-turn/partial-turn pots | slowpogo | Parts | 1 | 12th January 2007 07:40 AM |
| help customize "slow turn-on" duration in this circuit (link to schematics inside) | jarthel | Power Supplies | 10 | 17th August 2006 06:05 PM |
| Slow turn-on for LM78XX regulators? | JojoD818 | Solid State | 0 | 15th February 2004 11:16 AM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 01:43 AM |
| Page generated in 0.08180 seconds (82.91% PHP - 17.09% MySQL) with 11 queries |
