Old 9th May 2007, 03:32 PM   #121
sixtek's Avatar
Nice results!
Thanks Netlist!
What SIM software are you using? I cannot identify it (I'm usig Tina, Multisim (aka EWB) and Simmetrix).
In real life, PL only use two big capacitors, not bypassed.
And it never caused any instabilty at PL-700? 99% of amps have bypass cap on the board.
Maybe it would be a possible upgrade of PL-700 to solder caps on the amp PCB?
Old 9th May 2007, 04:05 PM   #122
Netlist is offline Netlist  Belgium
Netlist's Avatar
Simulator is Microcap.
When you read back in this thread, you will find that some of us are attempting to rebuild this amp. The sim has no other purpose then to get more insight in the possibilities to do so.
/Hugo
Old 9th May 2007, 04:19 PM   #123
Netlist's Avatar
-3dB points are between 10Hz and 107kHz:
Old 9th May 2007, 04:25 PM   #124
Netlist's Avatar
Here is the circuit file:
Change the extention to .CIR
Phase Linear 400, SERIOUS AC! Planerguy Solid State 41 29th March 2009 02:41 AM
FS Phase Linear equalizer woody Swap Meet 4 14th August 2008 09:50 PM
Phase Linear Model 200 help needed Original Burnedfingers Solid State 14 11th November 2006 02:54 PM
how to bridge 2 phase linear amp? shobbo Solid State 1 28th March 2006 05:17 AM
Phase Linear lumanauw Pass Labs 3 17th December 2005 02:38 AM
Page generated in 0.07999 seconds (67.78% PHP - 32.22% MySQL) with 11 queries
