#111 | |
Hi d3imlay,
-Chris |
#113 | |
Hi Pete,
-Chris
"Just because you can, doesn't mean you should" © my Wife |
#114 |
I found some time to finish modeling the 700B.
Picture is the best I can produce, Transistors are what was reasonably available in Microcap except for the Ge's Q8 and Q9 which are standard models. I can pass the model text file to anyone interested. /Hugo |
#115 |
Hi Netlist,
I'm interested in SIM results. Are there any data (THD, noise, square-wave responese, etc...) you could share with us? Thx, |
#116 |
Device conditions:
#117 |
PS:
Hmmm... Strange.. PL had not used any rail bypass capacitor? Something polyester in 47n-470n the range, optionally bypassed with 10u-100u elkos? |
#118 |
Gain:
With a 1Khz sine wave of 6.44Vpp at the input the output slightly clips at 189.58Vpp into 8ohm. If my calculation is correct: VRMS = Vpp * 0.3535, the ouput power would be 561 WRMS. /Hugo |
#119 |
sixtek,
In this simulation, I have omitted the PSU caps as this is supposed to be battery operated. In real life, PL only use two big capacitors, not bypassed. I can post any results you want, given that I know how to perform them in Spice. /Hugo |
#120 |
Square wave input 1Vpp, output 30Vpp.
I'm still searching how to change the frequentie of the square wave model to make it say 10kHz. Edit: This should be 10kHz. /Hugo |
| Phase Linear 400, SERIOUS AC! | Planerguy | Solid State | 41 | 29th March 2009 03:41 AM |
| FS Phase Linear equalizer | woody | Swap Meet | 4 | 14th August 2008 10:50 PM |
| Phase Linear Model 200 help needed | Original Burnedfingers | Solid State | 14 | 11th November 2006 03:54 PM |
| how to bridge 2 phase linear amp? | shobbo | Solid State | 1 | 28th March 2006 06:17 AM |
| Phase Linear | lumanauw | Pass Labs | 3 | 17th December 2005 03:38 AM |
| Page generated in 0.11155 seconds (76.32% PHP - 23.68% MySQL) with 11 queries |
