Hi all:
I recently read about National's new audio opamp - the LM4562. I got a few chips and decided that my first project would be a phono stage. I decided to build the example single gain block design provided in the datasheet. So, a little pcb layout work with PCB Express, some etching and drilling and I had a board. Some soldering and I had a circut. Power up and, well, Ill be d^&*ed - it works! BUT (theres always one - at least) it hums. ![]() It has a pronounced 60Hz hum that I cant identify the source of. Looking with the scope, the PS rails are clean, the input is clean, but there is a distinct AC hum on the output - about 15% of the total volume. Can anyone suggest how I can find the source of this hum? I would appreciate any suggestions. |
#2 |
The PCB is single sided and looks like this
#3 |
Heres a photo so you can see what it looks like.
#4 |
Since you have a full bridge, I'd expect the hum to be 120Hz + harmonics.
I don't see any bypass caps on that chip... |
#5 | |
The datasheet indicates that the 4562 has a PSSR of >110db. Would this not eliminate any ripple from the rails getting into the output? And, there is no mention of bypass caps in the applications section. What am I missing? |
#6 |
- Your PCB layout contains several ground loops and it's overall quite poor. As a result, PSU capacitor ripple current from the unregulated side is being directly fed as voltage into the inverting input of the op-amps and amplfiied with the full RIAA gain.
- A phono preamplifier involves sub-milivolt signals and high impedance nodes, thus it requires careful electrostatic shielding, yet your PCB is attached to a bare wooden box. That's absolutely unsuitable. - The 7912 regulator is not properly wired in the PCB mask shown. I suggest starting a new PCB layout from scratch (conceptually the circuit is fine), but you have a lot to learn about PCB routing. You should have posted your layout here and asked for improvements before etching the PCB. Tip: Read about star grounding techniques.
I use to feel like the small child in The Emperor's New Clothes tale |
#7 |
Eva, could you please post some links about pcb design? I am interested in ways of designing more complex circuits than this one, but some basics wont´t hurt too.
#8 | |
I am very happy to start over. Any suggestions on where to begin? PS: I caught the error on the 7915 reg during the build and managed a work-around. Jess |
#9 |
Hi all:
For those of you who might be interested how this turned out, I got the hum fixed. A freind offered a suggestion for a very simple mod (see PCB image. This killed the ground loop and the hum. Initial listening impressions are: superb bass, very balanced and natural overall. Highs seem a bit reduced (but just a bit). This is probably due to my choice of eq caps. Next one I will get first-rate caps and, in the meantime I will be working on my PCB skills. If anyone has any suggestions where to get beginner's info on PCB layout, I would appreciate it. Onward and upward (hopefully). Jess |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| Phono Stage... | ncdrawl | Analog Line Level | 1 | 5th November 2008 10:14 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| PS for phono stage | trianglezerius | Power Supplies | 0 | 20th March 2007 12:14 AM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Page generated in 0.10925 seconds (79.64% PHP - 20.36% MySQL) with 11 queries |
