I have some DC offset in the ML 23 that trips the breaker intermittantly when ramping up with my variac. I believe it is in the input section after isolating the HV supply to output transistors. Has anyone had this problem with the No23? I already see a couple caps near some heat sources that need replacement however they are not shorted. This is a very difficult amp to take apart which requires that all the outputs be unsoldered and removed before the main board can be worked on. I would like to get it right the first time and was hoping someone on this forum has some experience with this amp.
#2 | |
Many designs have DC offset , when they are feed with to low a voltage (depending of the circuit )... Have you tried to feed the amp with the proper voltage?
Jorge |
#3 |
I should of specified 19v DC offset when bypassing the protection circuit.
I get 67,67,37v at differential pair but the transistors test OK. I think this amp uses FET at the input which I would suspect is the problem. A schematic that is legible would be nice if someone could kindly send one my way. I would like to identify the FET on the board without reverse engineering everything. |
#4 | |
But this offset is with rails at full voltage , or at low voltage when you feed the amp progressively via the variac?
Jorge |
#5 |
Full voltage or or 3/4 voltage. Compared to the good channel as well. I think its the LM394 bad.
#6 | |
Yes... probably the problem is in the input pair LTP, a schematic could be handy... It don't have a nulling offset servo , like a integrator Op Amp..?
Jorge |
#7 |
Jorge |
#8 |
The datasheet says direct replacement for the LM394. There seems to be some minor differences but looks like it may work. This is what the No23.5 uses according to some other posts I found.
| Mark Levinson ML3 or No23 ???? | johnsciolino | Solid State | 3 | 6th June 2011 10:15 PM |
| Can someone help with Mark Levinson JC-2? | atlantaudiophil | Solid State | 22 | 3rd December 2009 12:16 PM |
| Levinson 23.5 | srivenkat | Solid State | 0 | 16th June 2008 02:14 AM |
| LEVINSON 333 Schematic?? | bear | Solid State | 11 | 7th February 2005 04:51 PM |
| mark levinson | karma | Swap Meet | 8 | 8th March 2003 01:42 AM |
| Page generated in 0.11811 seconds (77.40% PHP - 22.60% MySQL) with 10 queries |
