Frome ESP P3a webpage:
"Note that like the original, there is (still) no output short circuit protection, so if speaker leads are shorted while the amp is working with a signal, there is a very real risk of the transistors being destroyed." If I use a fuse or two on the speaker terminal, will this be enough protection for the output transistors, if I get a short circuit?
Roger |
#2 |
If your amp has a correct V/I limiting circuit this should protect your amp, but a fuse may also do the trick......
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
OK, I will use some fuse then.
Thank for the reply.
Roger |
#4 | |
Account Disabled
#5 |
mikeks;
Yes if it's small
#6 |
Account Disabled
No
#7 |
mikeks;
Let me hear your arguments
#8 |
Yes, Let us hear your arguments
Roger |
#9 |
a fuse is too slow to protect semi cons. Putting in a smaller speaker fuse to speed up the cut off will make the distortion even worse. A far better protection system is fast acting IV limiting for near DC conditions and slower acting to allow the transients through. Then put in supply rail fusing for longterm overload to prevent the heatsink overheat taking out the current limited transistors.
regards Andrew T. |
#10 | |
A small "F" fuse may protect the output.... Please note the may in my respons in post 2
| Need help with NAD amp! Goes in protection | silversweden | Car Audio | 42 | 24th January 2008 08:29 PM |
| DC-protection? | Skorpio | Solid State | 4 | 1st December 2007 09:09 AM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| protection | Dj BASS AMP | Solid State | 7 | 26th March 2003 09:53 AM |
| Page generated in 0.09594 seconds (75.71% PHP - 24.29% MySQL) with 10 queries |
