Old 29th October 2006, 10:51 PM   #1
packer is offline packer  United Kingdom
Default C Audio SR606 Schematic
Greetings,
Could any one help with a schematic for an early SR606?
I have approx -25v sitting on the P & N terminals on the drive PCB.
when I remove these connections from the drive PCB and take them to ground Amp comes out of protect.
Located open zener on +18v supply replaced it and the op amp.
Removed all transistors on the drive PCB and tested with a DCA60
none reported faulty.
any help would we welcome..
Old 30th October 2006, 01:43 PM   #2
Default email address for SR606 Schematic
Hello,
If anyone has a schematic for this could you plese mail it to tsc@f2s.com
I am not able to mail member "kamskoma" Who has one
if another member could contact him for me I would be extremely gratful.
Old 19th June 2007, 01:49 PM   #3
Default SR fault
Hi Packer,
first things first, you need to replace R24, R34, and R50 with 27k 1W PR01 resistors and mount them so they are at least 10mm off the pcb.
the existing ones will either be 22k, or 24k and may be 1/4W or 1/2W
If you have had to replace the 18V zener in the op-amp supply replace the TL071 as well.
the schematic will follow shortly which shows the resistors to change.
changing these resistors will fix around 80% of SR faults if not drop me a line on
lee.basham@lj-electronics.com
or call me on
07768551482
thanks
Lee Basham
c-audio sr606 and sr808 power amps dennis1442 Solid State 4 22nd April 2010 06:38 AM
Schematic: Audio Innovations, The first audio amplifier maartentje Tubes / Valves 22 25th February 2010 06:34 AM
C-audio SR606 Power Amplifier kamskoma Solid State 51 22nd July 2009 11:28 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
Pre Amp schematic Audio Note M1 Rune Tubes / Valves 0 26th April 2004 04:50 PM
Page generated in 0.07375 seconds (68.17% PHP - 31.83% MySQL) with 10 queries
