Old 29th October 2006, 07:15 AM   #1
Default loud thump when powering up my amp
i know many older solid state amps do this, but for the sake of being specific, it is a 70's 'polytone custom bass amp 100' combo that i am having this problem with. i would like to stop this loud thumping sound when i turn on the amp, at least for the sake of protecting the speaker. it also thumps when i turn the amp off, though not quite as severely. ive already tried putting a .01 and then a .1 poly cap across the on/off switch, but neither helped at all. like i said, i know this is normal for some amps but with this amp it is a particularly loud thump - and i want it gone or lessened. i would really appreciate any suggestions or solid advice.
Old 29th October 2006, 08:36 AM   #2
pinkmouse's Avatar
With an old amp it is likely that some of the electrolytics in the biasing or feedback have dried out. A blanket replacement of all electros is probably a good idea. Pop the lid, and give us a couple of pics.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 29th October 2006, 07:53 PM   #3
hi - ive already done that. i thought it would take care of some of that thumping, but its exactly the same as with the original electrolytics.
btw, i dont want to have to build some kind of elaborate speaker protection delay circuit. ild prefer a simple solution, if there is one. i just want to enjoy my amp. i just finished 'restoring' it. i may want to tweak one of the channels later to give it a little mid boost, but otherwise its done.
thanks for the response!
Old 29th October 2006, 10:39 PM   #4
pinkmouse's Avatar
OK, it's probably a "design feature".
Two options, a switch in the speaker output to turn the drivers on and off, (only do this when not playing anything through the amp or the switch will rapidly arc out), or a muting circuit. They are not really that complicated, have a look at Rod Elliot's site for some ideas.
Al
Old 30th October 2006, 12:54 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Is it a single supply powered amp???
Old 30th October 2006, 01:00 AM   #6
FastEddy's Avatar
Single supply = yes.
denimvenom: You are probably in love with the looks and the "tube like" sound. You might consider replacing some of the parts with more modern technology.
Old 30th October 2006, 01:34 AM   #7
It isn't that complicated as you might be thinking of, or is it?
Old 30th October 2006, 02:06 AM   #8
FastEddy's Avatar
According to this: " ... 90 watts, solid state, closed back, 2 channels each with two 1/4" inputs volume, bass and treble controls ..." ( from http://www.elderly.com/vintage/items/130U-7722.htm ) ... it would not be too hard to do a total make over, a DIY Upgrade ... throwing in a couple of decent 90 to 150 watt amp modules of modern technology and adding a simple, dual channel pre-amp with tone controls ... The power supply transformer is of an older type, but the power rails (+ / - DC voltage) would lend itself to a nice upgrade. (Of interest: http://aussieamplifiers.com/nx150.htm ... works on rails from +/- 40 VDC through +/- 65 VDC ... but there are many, many more available.)
(The really great thing about DIY modding up an older amp for the stage ... you would amaze your compadras with a really great, clean, clear sound ... and no one will ever steal it as it looks so old and funky.)
Old 30th October 2006, 02:18 AM   #9
sorry, I mean the anti thump circuit.
Old 30th October 2006, 02:54 AM   #10
FastEddy's Avatar
I do too ... my solution may sound like a sledge hammer for a tack hammer job, but as long as your adding circuits and parts, you might as will fix all the problems ... (Im a little more into total DIY than simple slap dab, make due repairs, sorry.)
turn off thump jayme Tubes / Valves 6 23rd September 2007 07:40 PM
What is that thump,thump,thump? 65blkbkgt Car Audio 7 17th June 2007 01:35 AM
On & Off Thump Kinger Chip Amps 2 31st December 2006 11:46 AM
Zen amp turn-on thump. vdi_nenna Pass Labs 2 22nd October 2000 07:27 PM
Page generated in 0.10874 seconds (78.22% PHP - 21.78% MySQL) with 10 queries
