This is for a DAC I/V, using transistors and cascodes in the jocko style. Since it is open loop the main source of error is transistor base current.
I have spent a few hours hunting transistors and have so far found the perfect one, except noone sells it. So I'd be very grateful if you could share your finds. Here are the prerequisites : - Vce max : 30V, maybe 20, but I don't need a high voltage part unless it has other advantages. - Maximum current 100 mA - Power dissipation 0.2 W (will fry SOT323 chips) - PNP and NPN, complimentary part would be nice Now before someone says "BC547C" : - high hFe (>2-300) - constant hFe between 5 and 30 mA with the curves to prove it - LOW CAPACITANCE See these graphs : - BC547C gives up long before 10 mA - BC317/337 would be good but it oscillates in Spice - ZTX851 starts its linear region AFTER 10 mA - MMBT489 is perfect but too low power dissipation and high capacitance Thanks to anyone who can help !
#2 |
BC557C. Easily obtainable. I just picked one at random and obtained this - hfe = 400 @ 10mA.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
That was a quick reply, but unless the datasheet curve is wrong, this transistor isn't suited for the application... look more closely at the hFe versus Ic curve that I posted ; it has a knee at about 10 mA.
Using BCP56 or BC317-40 which has a flatter curve yields about 4x linearity improvement, but 317 oscillates in the simulator. BCP56 might be suitable but it has large capacitance. Can your gear trace hFe vs Ic (this was Ic vs Vce for various Ib, right ?) |
#4 |
You could consider jocko's favs.... (If I remember correctly)
#5 |
Hello Peufeu
Have you looked for superbeta transistors? Some might be suitable; maybe it will be difficult to find one with your voltage requirements. You could also opt for a composite: it is easier to achieve good performance in every respect than with a single device: see the discussion here: http://www.diyaudio.com/forums/showt...15#post1023315 LV |
#6 | |
#7 |
Check this :
http://audio.peufeu.com/node/57 Superbeta. Interesting. Do you have references of ones you like ? I'm simulating BF861C JFET but it's academic only as noone sells it. I'm gonna try obtainable JFETs first |
#8 |
here's some suggestions but you'll still need to check they meet your criteria. 2sb716/d756 2sa1085/c2547 2sa872/c1775 2sa1350 2sa1815/c4432 2sa1845
regards Andrew T. |
#9 |
If some transistor produces oscillation in the simulator, don't discard it, blame the model instead.
Also, simulation becomes completely inaccurate when trying to predict exact gains and capacitances of bipolar transistors. Models are not that good. And last but not least important, given the same part number, gain magnitude and linearity and capacitances change from one manufacturer to another and from batch to batch, so a curve tracer is strongly recommended instead of simulations.
I use to feel like the small child in The Emperor's New Clothes tale |
#10 |
I looked at the datasheets and 2SA1845 might have potential.
Eva : I know. Some models are quite suspicious, especially BC317/327/337. I will test them in circuit when I make the test boards and we'll see. So far JFET simulations fail to bring improved linearity ; it's difficult to find the right PJFET, too. |
| El86 driving high beta bipolar power tr | npr | Tubes / Valves | 5 | 21st January 2009 03:27 PM |
| Transistor Beta Numbers & Matching Q? | Zero Cool | Solid State | 12 | 18th May 2006 03:41 PM |
| Can I get a few part numbers for Pots? | Destroyer OS. | Parts | 5 | 19th January 2006 08:20 AM |
| transistor part numbers | bjr | Parts | 2 | 4th September 2005 04:26 PM |
| SMD part numbers? | nuppe | Parts | 0 | 15th December 2004 10:04 PM |
| Page generated in 0.12023 seconds (80.36% PHP - 19.64% MySQL) with 11 queries |
