Old 25th October 2006, 08:45 PM   #1
Default tips for first time builders
Hello everybody. I am new to the diyaudio site. I am going to buy two of the aussie amps nx150 Mosfet amp modules to make a stereo power amp. Any tips out there for a first time builder? I plan to use a rack mount chassis to house the completed amplifier. The power transformer will be a 320 VA EI frame transformer as opposed to a toroid. Since I've heard EI's give off more stray magnetism than toroids do, what would be the best way to orient the transformer in the chassis to reduce the potential effects of stray magnetism?
Old 25th October 2006, 11:51 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Bama Slamma,
I'd say you should mount your transformer near the front on a sub chassis. Rotate it after you get everything in there for the lowest hum level. A steel panel separating the electronics from your power supply may be a good idea.
-Chris
Old 26th October 2006, 05:22 PM   #3
I learned this the hard way. Good newbie tip.
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
one for the box builders offroadbum Car Audio 2 11th October 2004 09:19 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Page generated in 0.09482 seconds (63.25% PHP - 36.75% MySQL) with 10 queries
