Bob Cordell Interview: Error Correction
Old 2nd December 2007, 01:04 PM   #2961
syn08 is offline syn08  Canada
Default Re: Re: Re: hec != hoax ?
Originally posted by Edmond Stuart
I really hate bias circuits that cripple the VAS
I was thinking about those 5 little VDC symbols sitting like thorns in my eyes :-))
Old 2nd December 2007, 01:13 PM   #2962
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Originally posted by lumanauw
Hi, Edmond,
Discussing about VAS drive, what is your opinion about this kind of VAS drive? This is from SKA topology. It boost the gain of the VAS drive, (making it high impedance) by using bootstrap (R2+R3+C2). Then feeded to emitor follower Q5. From here, it drives the VAS stage (Q7-Q8, but here Q7-Q8 are already power devices).
Hi lumanauw,
What else could I say about this circuit, as most ins and outs you have already figured out by yourself.
To be honest, I don't like this circuit at all, because the bias of the output stage is not well controlled, for example.
Cheers, Edmond.
Old 2nd December 2007, 02:25 PM   #2963
andy_c is offline andy_c  United States
Banned
In Greg's actual design, the input stage current sources are a function of heat sink temperature to compensate the output stage bias. I had some email conversations with him about this a couple of years ago. He was trying to get me to tweak the level 3 SPICE models of his output devices so the simulated and measured tempco agreed. It looked too time consuming, so I gave up on it.
Old 4th December 2007, 06:29 AM   #2964
KSTR is offline KSTR  Germany
KSTR's Avatar
@Edmond:
Thanks for elaborating on the VAS details... I get a clearer picture now (still it's not intuitive to me... I need to sim it to really get it, it seems). Also, that 40ppb THD20 @300mA is really stunning, though I assume this figure is for the complete amp, not the OS in isolation.
@all, FWIW: Here I played a little with that autobias class A OS, and as it deals a little with error correction / feedback in two regards (#1: error cross-feed, #2: separating voltage and current terms in the feedback loops) you might want to take a look there (comments welcome). As of now, I abandoned the output stage concept I posted here a while ago, since this autobias thing does the same performance with lower parts count and simpler topology, all cheap discrete stuff.
- Klaus
Old 4th December 2007, 03:44 PM   #2965
Default Re: Re: Re: Re: hec != hoax ?
Hi Ovidiu,
Thorns are gone.
Cheers, Edmond.
NB: This is not a complete amp: no protection, no Zobel network, no servo etc.
Old 4th December 2007, 06:56 PM   #2966
Default Re: Re: Re: Re: Re: hec != hoax ?
Thorns are gone.
They are :-)
Now, how would you compare this design complexity with respect to the PGP amp?
But after considering each amp simulated performance?
Old 5th December 2007, 10:36 AM   #2967
Default Re: Re: Re: Re: Re: Re: hec != hoax ?
They are :-)
Hi Ovidiu,
Of course the front end is less complex, as it lacks a NDFL stage. Nevertheless, due to TMC, the distortion is about at the same level.
OTOH, the offset voltage is quite large (0.5V), so a servo needed, which adds to complexity (an op-amp, +/- 15 PSU, etc.).
Notice that this is not just a TMC amp, rather a double TMC amp (DTMC). Not only the take off point is 'TMCed' (see: R26-27 and C7-8), but also the feedback input for the Miller compensation is 'TMCed' (see: R17 and C4-5). As a result, at AF the Miller cap (C6) is effectively connected from the output right to the inverting input, while at HF the Miller cap is effectively connected between VAS input and VAS output. This arrangement ensures an extreme low distortion of the front end and a very modest drive requirement of the input stage (biased at a mere 1mA).
BTW, DTMC is only compatible with a CFB input stage, thus no LTP, let alone configurations with an additional gain stage between the IPS and VAS.
Cheers, Edmond.
Old 5th December 2007, 03:39 PM   #2968
Bob Cordell is offline Bob Cordell  United States
Default Re: Re: Re: Re: Re: Re: Re: hec != hoax ?
Hi Ovidiu,
Cheers, Edmond.
Hi Edmond,
Although I don't call it "DTMC", the approach of taking the TMC path from the output of the amplifier back to the input is the way I have applied TMC to my input/VAS architecture. That is a fairly obvious extension of my favorite type of feedback compensation to TMC. Indeed, TMC inclusive of the input stage is quite compatible with an LTP input stage as shown in the schematic below.
That simulation yielded 0.001% THD-20 out to 200 kHz at 100 watts into 8 ohms with a simple and straightforward version of my amplifier that did not use EC.
The TMC path includes C5, C2 and R36.
Note also that the input cascode is bootstrapped with a replica of the input signal derived from the output signal via R3 and R27. I have found that doing so reduces a significant contributor to distortion that was in my original MOSFET amplifier design.
No Early effect mitigation is used in the VAS of this simple design.
Bob
Old 5th December 2007, 03:57 PM   #2969
Hi Ovidiu,
Cheers, Edmond.
It would be interesting to describe the pros and cons for each approach (NDFL vs. TMC). If the performance (not only THD20, but also PSRR, SR, IMD, DIM, etc...) is the same, then why/how would one chose between NDFL and TMC?
You know I am a little skeptic regarding TMC (in particular about delivering under 1ppm THD20 with a reasonable phase margin). I have to build and measure such an amp to find if it really delivers to te expectations and better understand what's the price of this approach and how it would compare to NDFL.
As a rule, I think it would be always a good idea to show both sides of a certain new design approach. As you know, there is no free lunch... Maybe defining a consistent set of parameters against each design should be evaluated, both from a simulation and measurements perspective, would help?
BTW, another issue that must be addressed to make such designs more appealing is to make the simulation results reproductible. Unfortunately, it seems that PSpice (at least the Cadence/OrCad version that I am using) is unable to always reproduce your numbers, even for simpler designs and even if the device models are identical. I think it would be a good idea to define a set of simulation benchmarks, to provide consistency across platforms. I think this is important in particular for "sensitive" topics like THD, IMD, etc... and I don't think it's realistic to expect that everybody should use and trust Micro-Cap.
I know, unfortunately there's nothing sexy in such work, but I don't think there's other way to raise the level of confidence in a certain design. Of course, I am assuming you find confidence and results consistency important.
Old 5th December 2007, 06:13 PM   #2970
Default Re: Re: Re: Re: Re: Re: Re: Re: hec != hoax ?
Originally posted by Bob Cordell
Hi Edmond,
Bob
Hi Bob,
Perhaps you should have a closer look at my latest schematic. I insist that it is DTMC, not just TMC, because:
"also the feedback input for the Miller compensation is 'TMCed' (see: R17 and C4-5). As a result, at AF the Miller cap (C6) is effectively connected from the output right to the inverting input, while at HF the Miller cap is effectively connected between VAS input and VAS output."
Before making any comment on your schematic, please increase the font size, as the component values are hard to identify.
Cheers, Edmond.
Bob Cordell Interview: Error CorrectionHide this!Advertise here!
