Bob Cordell Interview: Error Correction
Old 8th December 2006, 09:57 PM   #1421
ingrast is offline ingrast  Uruguay
Originally posted by gootee
.... I'm sorry to have brought it up without first doing some research.
- Tom Gootee
Nobody can possibly be aware about everything that is going on, this is a splendid clearinhouse in this respect.
Rodolfo
Old 8th December 2006, 10:30 PM   #1422
gootee is offline gootee  United States
Originally posted by mikeks
Reducing K4 from 50 to unity (with the same misalignment of 10% in the gain of summer S1) causes THD to increase by a significant amount, to 0.17%.
Thus, although the magnitude of K4 has no effect at balance, when such an imbalance exists, then it desirable that K4 be made as large as possible to desensitize the loop to the error.
Indeed, increasing the gain of K4 to 1K reduced THD (with a misalignment of 10% in the gain of summer S1) to just 0.00035%.
These results seem to confirm Hawksford's findings, and, on this basis, the circuit modification above is recommended.
Nevertheless, whether these results are replicated in practice remains to be seen.
Discuss.
Mikeks,
I appreciate all of the work that you've done, on this. I have been trying to follow this part of the discussion, even though my knowledge of control theory and mathematics is a bit rusty. But, mainly, I have found it to be difficult to re-navigate the thread, well-enough, due to the number of messages involved, and also all of the links to previous posts, intervening and conflicting posts, corrections, repetitions, et al.
I don't like to be a bother. But, do you already have, or can you provide, a summary, or a single document, or, maybe easiest, a properly-sequenced list of links, that includes all of the really-relevant stuff, so far, "all in one place"? That would also make it much more accessible for everyone who tunes-in later.
If that's not practical or desirable, from your point of view, please feel free to just forget that I asked.
Thanks.
- Tom Gootee
Old 8th December 2006, 10:42 PM   #1423
mikeks is offline mikeks  United Kingdom
Account Disabled
Originally posted by Bob Cordell
Actually Tom, I've already built a test instrument similar to what you describe. It is called the Distortion Magnifier. I first used it to test my MOSFET power amplifier over 20 years ago. I described the technique briefly in my MOSFET amplifier AES paper.
A more up to date and detailed description of the Distortion Magnifier is provided on my website at www.cordellaudio.com. Just look under "Distortion & Distortion Measurement", then click on "Sensitive Distortion Measurement". I soon hope to have an even more detailed description of the DM on my site.
Bob
Howdy Bob,
Thanks for those pictures of the RMAF. I look foward to attending next year.
Do you have or intend to have any audio products for sale on-line?
Cheers.
Mike.
Old 8th December 2006, 10:47 PM   #1424
Rodolfo
Rodolfo,
You are right! But I also appreciate your kindness for having mentioned it.
- Tom Gootee
Old 8th December 2006, 11:00 PM   #1425
Account Disabled
.......can you provide, a summary, or a single document....
- Tom Gootee
I'll probably get around to doing this, though not immediately.
I've gone to great lengths to link each post to a preceding one in the interest of continuity; navigating your way through these links can't be that difficult, surely.
Old 8th December 2006, 11:21 PM   #1426
powerbecker is offline powerbecker  Germany
Heinz,
Thanks!
I could not resist trying to make it better:
To get a fast step response with no overshoot or ripple, and the same with 1 uF in parallel with the 8 Ohm load, I had to "cheat" and add a NFB loop (AC-coupled!).
Now, there is NO overshoot or ripple in the step response into 8 Ohms. And it's still _almost_ as good with 1 uF added (w/ESR .02). [Steps: 20v p-p output, from 1v p-p pulse input with 2.5 us edge times.]
It can be made more stable with >= 2 uF by increasing C22 to 560 pF or more, at the expense of a slight degradation of the step response when 1 uF or 1 pF is paralleled with the load. The THD-20 can be made lower, also, but probably only at the expense of the quality of the step responses, AFAIK (as far as I know).
THD is .000230%, for about 20v p-p into 8 Ohms (.000229% w/1uF). (Output amplitude was adjusted by changing input amplitude, to match the output amplitude of your ec_amp-hb2.asc circuit, for comparison.)
The EC-Amp-tg3.asc LT-Spice circuit is attached. Remove the ".txt" from the filename.
The circuit is a little troublesome, sometimes, for me, with LT-Spice, especially when using the pulse input. I would like to try, for example, lowering the resistances near the end of the ec loop (R26, R19, R20), or raise R30 to increase the ec loop's gain, but always get a "timestep too small" message from LT-Spice. Similarly, I cannot even lower the pulse input's amplitude without getting an "iteration limit reached" message, which I also get when trying to run an AC Analysis.
- Tom Gootee
Tom,
now I cannot improve it!
Thank you for your excellent work!
Heinz!
Old 9th December 2006, 12:03 AM   #1427
Originally posted by janneman
Well, in electronics like in real life, brute force often has the edge . But playing with ec is quite interesting. Notwithstanding the discussions here that it is equivalent to nfb, the character, if I can call it that, of an ec amp is definitely different from a nfb amp.
You really have to think differently, there is no longer the overriding concern to get very high gain. What strikes me is the almost complete adsense of oscillatory tendencies, ec circuits (at least in my experience) tend to be very docile.
If you are looking to something different from the tired old ways, ec amps are worth a try!
Jan Didden
Jan, there are many ways to Rome....I look always for the shortest (corresponding to my knowledge)
Till today I have never seen EC design which beats NFB.
The proof of the pudding can be, to improve a classD stage with itīs "nice" filter at the end. Here end the way for NFB....
I dontīt try it till now and Iīm not all too optimistic.
For the same purpose I did some simulations with feedforward EC.
This works quite good but it ends always with a far to big correction amp... at that time I also missed a good idea!
Heinz!
Old 9th December 2006, 07:13 AM   #1428
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Thanks for those pictures of the RMAF. I look foward to attending next year.Mike.
Me 2!
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 9th December 2006, 07:16 AM   #1429
jan.didden's Avatar
Mike, indeed, your efforts to keep your posts consistent and the story continuous are great. Still a single document would be even greater - whenever you get the time!
Jan
Old 9th December 2006, 09:23 AM   #1430
Originally posted by powerbecker
Tom,
Heinz!
Heinz!,
Thanks so much for the encouraging words!
You are probably being way too kind. And I probably just got lucky, accidentally. But still, it's always great to hear some praise, especially since I have only been dabbling in electronic design for the last several years, and only seriously for the last two years, after doing no EE work at all for about 15 years, and knowing mostly only control theory and not too much about actual circuits, before that.
Thanks again! Back to the circuits...!
- Tom Gootee
Bob Cordell Interview: Error CorrectionHide this!Advertise here!
